My car's only done 10 000 k's and I'm thinking of trying to keep the injectors clean by occasional bottle of engine cleaner. Every 10 000km's or so
I like to use Liqui Molly products so I'm thinking of that
Any thoughts whether it's ok running it in sidi engine and what other brands seem to work for you ?
I agree with kuzman89. run some 98 through it. I've been told from a few people to stay away from all those additives.
i run 98 all the time
seconded.
the next time you know you are going on a long drive, buy some good fuel and it'll do the same job when the engine gets really hot. 2 hours on the hwy will burn away whatever little crap is in there.
but you've only done 10,000km so the chances of sludge build up already is next to nil (unless you constantly fill up with dodgy fuel).
If you're running clean fuel, like BP ultimate, the injectors should be pretty clean anyway.
Taking it to blue mountains tomorrow so I'll give it a bit![]()
one questions should u always wait till ur fuel is near finished b4 filling up or is topping up so ur full most time bad
I'm a boy who appreciates a good body, regardless of the make.
Ronald Reagan (1986)
i was always told taht if you let your car get really empty (like when the light comes on) if you have any sludge or whayever in your tank ... thats when it will suck it up ... so i try to fill her up when shes got a 1/4 or more in it ... that way i avoid this problem ... plus i use bp ultimate anyway so yeah
Put about 50mls of BioDiesel in the fuel tank when you fill it up
It will strip any deposits off the injectors
Crap in the tank is a thing of the past. With modern plastic tanks you dont get corrosion and fuel is filtered pretty well at the pump before it goes into your tank.
Fuel does degrade over time and lose octane rating but not over a couple of weeks.
I always run my tank to empty and have had no issues over 170,000kms.
Silver Certified.
I always try to fill up before I hit a 1/4 tank. Topping up continuosly, or letting car get to a 1/4 tank makes no difference. As RiCeY pointed out, fuel does degrade over time but not enough to worry about in just a couple of weeks.
Read this interesting article below. I found it while I was researching regarding fuel in tanks and how long until it affects performance etc.
Very interesting reading. Especially for guys who have high powered or even standard cars which only get driven on weekends and have a tank of fuel last 3 or 4 months or longer;
Does petrol/gas have a use by date, or can it be stored for years? | Answerbag
HoldenOnn: thankyou for that informative link.
I haven't run my VE (3.0 L SIDI) to dry yet, but I don't expect any trouble if I do, subject to having a full jerry-can nearby.
I ran my VZ (3.6 L) dry several times. After putting the jerry-can in, and putting the can, etc, back in the boot, the VZ started instantly every time:
electric fuel pumps are a great idea, I reckon.
The theory about sludge, accumulated dust &/or condensed moisture, or whatever, has been around for a long time. But, there are two responses -
never let your tank get low; or
empty it completely every once in a while, so that the crud doesn't build up.
For many years, I've worked on the "empty it completely" premise.
The problem with the VE is that I got 840 km out of a tankful, WITHOUT running empty (Coffs Harbour to Canberra), and I like the idea of not taking a jerry-can with me on future trips. A dilemma, I suppose ...
In the VY I always fill up when it's down to about 1/4 tank (roughly every two weeks usually)
I only use Caltex Vortex 95 and use Nulon injector cleaner every 3,000 k's approx.
Never had any issues with the Nulon and odomoter is on 144,000.
This is an Ecotec, though, not SIDI.
