Results 1 to 6 of 6
Thread: Sat nav green
    2010 VE SSV ute XYZ XYZ
    Jun 2011
    Default Sat nav green
    My factory fitted sat nav in SSV ute screen has green tinge - all over - everything else works
    Anyone else had this prob or have any ideas to fix?
    Holden VZ
    May 2011
    Jun 2011
    Yes - is still under warranty - just wondering if anyone knew the fault cause - I will take it back to dealer - they are very good
    Luke V8's Avatar
    Luke V8 is offline AKA Luke!
    VE Commodore SSV
    Feb 2011
    & once you get an answer come back and post it incase someone else gets the problem in the future
    Ve SSV
    Jul 2011
    Old problem.... It will also go red and other shades... On mine, the front facia of the display /comes is loose. The entire entertainment unit is one piece.. It's removes by putting your hand under it at the ash tray and gently pulling it back to you..It's held in by 2 plugs and two lugs...... There is a small pull down catch just under the front. Sometimes this is down. The Colour tint can be fixed on mine by either removing the unit and re=seating it or just press about where the CD's go in. Annoying problem, but easily fixed.
    Jun 2011
    Thanks Tony - much appreciated
  1. Green Vb 202
    By vb_commie in forum VB - VC - VH - VK
    Last Post: 27-04-2011, 05:40 PM
  2. green vx...
    By greenVX in forum VT - VX - VU - WH - V2
    Last Post: 29-11-2009, 10:04 AM
  3. Green VT On 20z
    By theused084 in forum VT - VX - VU - WH - V2
    Last Post: 13-10-2007, 06:54 PM
  4. fs: green vc
    By WILDPSI in forum Parts And Other Items For Sale
    Last Post: 01-05-2006, 02:43 AM
  5. green
    By isaac_2jz in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-02-2006, 11:57 AM
