hey all,
just want to know how you go about putting a amp and sub to the headunit, i have a ve sv6 2010
cheers
It can be done - just depends on how DIY you are.... Im not so I had mine put in for me but it works well (worked well in my VE) and now in the WK
Dont quote me but its something about running a line convertor from your stock amp into your new amp and then to the new sub... Install in the VE is also easy because the battery is in the boot... I disconnected the stock subs so as not to ruin them but leave the units in so it looks stock / no holes
See how you go, maybe flick D3CID3R a pm, he knows much more about it....
Let me know how you go![]()
"Now I definitely have to change my pants because I've just jizzed and shat myself at the same time" - Torquative while riding in MPRSSV up Macquarie Pass
NEW RIDE - LAZY 5.7L 04 WK STATESMAN - PICS AND RIDE THREAD UP SOON!!!
You can use a line out converter, or purchase an amp with speaker level inputs.
I have done it on my 07 sv6.
The hardest part was running the wiring from the rear doors to the boot,
But apart from that it is simple.
Rear door speaker wires to the boot, (left the rear speakers connected)
Wires into a line out converter, converter cost about $30, than connected my amp.
battery is easy to access for power and I used the 12v plug in glovebox for remote.
I mounted my amp to the under side of my parcel shelf.
I think that's everything.
I have done it I have 2 alpine type r's in my boot and replaced all speakers and amped them all... Pretty easy will post a pic for u to have a look. Did it all myself with help from a mate.
07 VE SV6
Mods: K&N high flow air filter in box, x-force 2.25" cat back system
Sound System: Alpine type r fronts and rears, 2x Alpine type r 12" sub, Boss audio 1500 watt mono Amp, Kicker 450.1 Amp
allright what i have done is removed the kick panel on the side of the headunit console (drivers side) i had to find a diagram to tell me what wires were for what speakers... i spliced into front left, front right, rear left, rear right i ran wires from there under the floor all the way to my boot from there i had to connect them to line converters to go into the amp. i could have gone straight from the doors but i didnt want to run 2 new sets of wires (1 pair to run to the amp as line in and a return from the amps to speakers) threw that little rubber tube (which is difficult to get 1 pair through) setting up the amp is easy enuff cos gotta love the batter in the boot positive to positive ground to the neg and ur remote to ur ciggarette lighter. but just as ur setting up subs id still look for the wires in the side of the headunit cos it is so much easier to hide 4 wires under carpet or under side panels and what not. can post a pic of the wires ur looking for if u wish just pm me or something but i cant tell u what was what it was a bit of guess and check system to find out which wires were for which speaker but i can for sure tell u exactly what wires ur looking for.
hope this helps a little
07 VE SV6
nice job, what did you do to the original wires you spliced into did you reconnect them back up? if so what connections did you use?
Nah didn't bother about reconnecting them back up just soldered new wires to the headunit wires. If I sell mine speaker amp is going with it. N I didn't want live wires going my doors as I didn't rip the old wires out just left them there and ran better quality threw the doors fr the amp. Also I have a 2nd batter in the boot it is behind the amps on the left hand side of that pic. Will post a pic of the wiring to the headunit tomorrow to give u an idea of which wires to go off.
07 VE SV6
Great thanks mate, could I run both a 4 channel amp and mono block?
U surely can. Depending on the size of the amps u may need a 2nd battery or an upgraded main battery I'm pushing 1479 watts and I couldn't run it at max without my 2nd battery.
07 VE SV6
^^ It's the amps that "handle" the subs.
The head unit merely provides the signal to the amps (via a LOC in this case)..
I'm considering doing this. Would anyone recommend a speaker upgrade as well? If I did that I'd probably just do the four 6" ones in the doors and leave the tweeters and center speaker in the dash.
If your going to upgrade your speakers amp them as well otherwise it won't sound any good.
How about a sound processor, if say you were going for 6.5" splits, 6" 2 way rears and a sub (4ch and a mono)
Do they make much difference?
I only have a 2ch but I'll try different things that ppl have suggested so far
I just tapped off the rear left door, u can access the wires where the door hinges are. Straight into the high in on the amp. It was good at the beginning, but now a year later the main speakers have had it so to say, sounds all distorted.
VE Sv6 | Custom Brakes | OTR Intake | Lowered Pedders | SSV Tips | Pioneer Subs | DRLs | Tints | Phantom Black |
Go the alpine type s won many competitions for sound quality
07 VE SV6
so what is the best way to keep the speaker working that you tap off? a split to the speaker and the LOC? justwondering about halving the signal is that a problem?
I taped into my rear door speakers. I left them connected and just ran an extra wire to my LOC. I've had no drama
got a loc today will be fitting this next weekend!!! did you use a terminal block or just wrap the new wires around the core of the originals?
I just cut and crimped. Used male and female crimps
