Results 1 to 6 of 6
Thread: coilovers
    astroham is offline PHATV6
    SIDI sv6
    Jan 2010
    Penrith
    Default coilovers
    i have a ve sitting on sssl's (new shocks to) i am not happy with the way it rides / handles / sits ... now i have gotten some info on coil overs and just had a few questions ...
    1)Does anyone know what the pedders coil overs are like / are they as good as they say they are
    2)Does anyone know anything about XYZ coilovers
    3)Does anyone know anything about the tein coilovers
    4)Is the $1000 price difference between tein coilvers and the xyz justified
    5)If i do coilovers is it still worth doing sway bars (was considering adjustable)
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    The price difference is definitely justified - that extra $1000 is so they don't snap.
    What shocks are you running? What don't you like about the ride/handling
    Pedders XAs are a decent entry-level 'coilover' - but you can get a better-performing set-up for the money.
    Teins are softer sprung but damped harder
    Definitely worth still upgrading the sway bars.
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    XYZ's you might as well use no springs at all. They are the definition of shit, I had them on my car for 2 hours then pulled out.
    If it isnt tuckin, it must be suckin
    2010 VE SV6 Ute and 2010 VE SSV Sedan
    Nov 2009
    VCM are currently doing a special on their Bilstein and H&R Coil over combo, fitted with wheel alignment, $1985.
    SIDI sv6
    Jan 2010
    Penrith
    Nov 2009
    Autotechnique - VCM Suite - VCM Performance - Harrop - Process West
    Street Performance Coil Overs - Bilstein Monotube—Suit VE Commodore
    Height adjustable to 10mm - 60mm on average
    Fine tune lowering to what you want
    H&R Street Performance Coil Overs are the perfect suspension solution for discerning drivers—from daily drivers to serious tuners—who can appreciate the awesome handling and superb ride comfort.
    Each coil over shock is custom valved to work in conjunction with a precision-engineered progressive rate spring, creating a finely tuned suspension system.
    The fully threaded shock body allows for adjustable vehicle height. This feature helps balance vehicle weight, resulting in a lower centre of gravity and improved performance and control. Rebound & compression adjustment is via an internal self adjusting system.
    Fitted & Aligned $1,985.00
    German Made || Serviced Locally || 5 Year Manufacturer Warranty
    There ya go.
  1. how low do coilovers go?
    By GEN3RATD in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-04-2011, 03:40 PM
  2. ve coilovers
    By jarrad88 in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-06-2010, 03:50 PM
  3. Coilovers
    By WogBoyz in forum VE Holden Commodore (2006 - ?)
    Last Post: 15-06-2010, 11:41 AM
  4. Coilovers for SV6
    By -**wHiStLe**- in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-01-2010, 06:49 AM
  5. Coilovers
    By Stupa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-04-2007, 09:46 PM
