Hey guys,
Last weekend i took all my wheels off and gave all my calipers a spray, when i had the rear wheels off 2 of the nuts were stripped (on the same side) so i got that fixed. Since i done this my steering wheel has been out by i dunno about 2 inches turned i'd say. Could anybody tell me why this would happen?
did you rotate the tyers ? and dose the car pull at all ? check tyer pressuer . also what did you spray the calapers with and how did you do it ? did you remove them at all ? check that the brakes are not sezed on one side
No i didnt remove them at all i sprayed them on the car with Anodized paint. The car is not pulling. No i didnt rotate them, how do i check if the brakes are seized? (i dont think thats the problem).
jack the front of car up and spin the wheels by hand they should be eazy and free if they fell hard to turn then you may need to remove the brakes and see what is causing the problem
