Results 1 to 18 of 18
Thread: Dynamat - worth it or not?
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Default Dynamat - worth it or not?
    I've been thinking of Dynamatting my boot, spare wheel well and under the rear seats to help get rid of the exhaust drone. Has anyone done this on a VE and is it worth the effort. Also, how much would I need to do that area and what's a good price to pay?
    Cheers.
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    I've been thinking about dynamat for my car too.... doing the doors at same time as audio upgrade, and also the boot as you've described. But I'm too much of a softy to rip apart my car (and I'm a complete noob when it comes to audio and soundproofing).
    From what I understand there are different types of dynamat available- thin shiny one and thicker black one, and in different sized packs. As Troy has already asked above, what sized pack is best and at what price?
    I'd even consider a 'group buy' for Canberra folk interested and maybe we can all get it for a better price.... just spitballing at present, I have no idea if such a deal would net any real savings?
    According to dynamat website, there is a specific product kit for the boot available (which by the looks of it has the normal thin shiny stuff as well as a liner of some sort over the top). Here's a link to website: Introduction
    Or there's this stuff specifically for the floor to stop exhaust noise: DynaPad
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    I havnt had any experience with the ve but from what I have heard/read, people get great results from this stuff. Apart from the apparent weight gain, but unless your morton its worth it.
    Sent from my GT-I9000 using Tapatalk
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
    VE SS 6L M6
    Apr 2011
    Perth, WA
    Deffiantly worthwhile, just did a mates boot full of the stuff, works good if you know where you're putting it
    Buy a bulk pack if you plan to do the wheel well, if you got spare you'll always find more noise lol. The tape is also nice if you want it to look clean etc. also SHARP knife is a must
    cheers - JD
    ps. dont buy cheap imitation stuff it doesnt work half as good!
    2007 VE omega
    Feb 2011
    perth WA
    Not sure how effective it would be on the boot of the VE due to it being plastic?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Personally, I would put a closed cell foam or something over the Dynamat to actually block/absorb the sound. The bulk pack is the best value for money. You can get it on eBay but beware of sellers who have removed a sheet (it should have 9 sheets). FHRX in Sydney also has good prices on it and posts it
    The last price I got was in January and it was $230 for a Dynamat Xtreme bulk pack shipped.
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    SSV Redline is offline You Ride I Ride
    VE Series II SSV Redline Sportwagon
    Mar 2011
    Definitely made a difference. We lined the doors and the cargo area including under the spare wheel of our wagon. The stuff is easy to cut, easy to apply and it stays put. All you need is someone who knows how to remove the door trims without braking the clips, scoring the paint or putting a screw driver through the trim. The guy who tinted our windows had to remove the door trims so we lined the doors with dynamat while the trims were off. Our auto electrician (the guy who installed the DVD players, iPad dock station and remote start button) said we should use the rest of the dynamat to line the wheel arches and reduce road noise. Sounds like a great idea to us but we'll wait until the shocks are replaced and the wheel arch liners can be removed more easily. The stuff aint cheap but it definitely made a difference to us.
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    I did my brothers ssv wagon with it and it made a bit of difference, wouldn't say it completely blocked all of it but there was an improvement for sure, i used dynamat xtreme. If you want some i have some left over, 4 or 5 sheets from memory if you're interested.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    did the whole firewall/floor of the pala' minus the boot. makes a HUGE difference. not only that, its a nice protective barrier against water [read rust]
    highly recommend.
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Quote Originally Posted by Juzo View Post
    How much did you end up using? If it was a pack and a half I might be interested in the leftovers you have.
    Nov 2005
    Warrnambool
    Holden VZ
    May 2011
    2010 VE SS-V Wagon
    Oct 2010
    Melbourne SE
    I was going to do the whole boot and wheel arches but unless you know how to take the trimmings off and have plenty of time on your hands say three quarters of a day then no point. Also the boot of the wagon has a plastic shell that is ribbed. So putting dynamat over this might not work. That's what I was told by a panel beater. I wasn't game enough to rip everything apart!
  15. #15
    Mar 2011
    I laid the dynamat over the plastic ribbed boot of our wagon and it has held fast. Had to as it doesnt stick to carpet so its hard to line the underside of the spare wheel cover. I was more worried about the vertical walls of the doors but it stuck fast in their. Its good stuff.
    I used 14 sheets out of 18 sheets. It was the Xtreme stuff.
  16. #16
    2010 VE SSV ute XYZ XYZ
    Jun 2011
    I had the entire cabin of my SSV ute dynamatted with dynamatt extreme and whatever the dynamatt is for the floor (it's different) - made a huge difference to noise as I have 3 inch exhaust etc - won't block all the noise out as noise comes through the glass and but also makes fantastic increase in sound quality of stereo although i have added an amp so stereo better anyway -won't get rid off road noise though but it does dull it
    Cost about $1500 installed
  17. #17
    Calais57's Avatar
    Calais57 is offline Donating Member
    VE Calais V 6.0
    Jan 2009
    Blue Mountains, NSW
    I am absolutely not an expert in this, but if you search the specialist car audio type forums there seems to be agreement that there is no point doing the whole of each panel.. I forget the recommended % but it's something like 40% I think. Not trying to be controversial. Just passing on what I have read elsewhere.
  18. #18
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    That percentage is to stop the panel resonating. In this case they're using the Dynamat to block the sound so the more, the better. Personally, I'd Dynamat the whole panels and then put a layer of MLV (mass loaded vinyl) or closed cell foam.
    In my old VT I actually, deadened with a Dynamat alternative and then put carpet underlay under the whole floor pan and it worked really well. But I don't think underlay is closed cell so I wouldn't recommend it for in a car.
  1. Dynamat
    By marcdon in forum Car Audio
    Last Post: 24-03-2010, 08:09 PM
  2. Dynamat??
    By Robbo VS3 in forum Car Audio
    Last Post: 09-10-2009, 12:38 AM
  3. WTB Dynamat
    By dawg in forum Swap / Wanted to Buy / Trade
    Last Post: 18-05-2008, 04:30 PM
  4. Dynamat. 11/10.
    By VNCalais98K in forum Car Audio
    Last Post: 20-02-2007, 08:27 PM
  5. Dynamat
    By 4PLAYN in forum General
    Last Post: 12-09-2006, 09:25 PM
