Results 1 to 5 of 5
Thread: diff gears and lsd
    2007 VE SV6
    Jun 2011
    Default diff gears and lsd
    This is a really noob question but can someone explain the difference between diff gears and lsd? i'm planning on 3.45 or 3.7. i'm assuming you cant just change the diff gears you'll have to buy the whole thing.
    JHP Vehicle Enhancements - Specialise in Holden Monaro and Commodore Spoilers, Body Kits, Tyre and Wheel Packages.
    Also what diff you better suit an auto ve sv6?
    2007 VE omega
    Feb 2011
    perth WA
    LSD is the centre of the diff which controls how much the two axles are locked together then the diff gears are bolted to the diff centre/LSD.
    2007 VE SV6
    Jun 2011
    so i'll need to buy the whole lsd like on the website and not just put in diff gears into the single spinnner to get both spinning?
    zapper-l67's Avatar
    zapper-l67 is offline LS# Eat One Today...
    VX Calais
    Jan 2010
    Western Vic
    Dude FFS get yourself a manual an familiarise yourself with your car.
    Differential Drive gears (where the ratio bit comes in) are very different to differentiating gears (STD single spinner) and Limited slip differentials (Clutch or Cone type reduced spin methods).
    Zapp
    This is the sort of stuff that happens when the kids get into Dads tool box over weekend.
    Money will be spent, Dreams will be shattered, Lessons will be learned, and a wealth of information will be gained.
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Buy the whole diff, that way you always have a replacement just in case you fry one down the strip.
    Plus, it's a job you can handle yourself. Swapping a ve diff is quite easily done.
  1. [QLD] WTD- Diff gears or whole lsd/spooled diff with gear set
    By Eliminator in forum Swap / Wanted to Buy / Trade
    Last Post: 21-07-2010, 07:29 PM
  2. [SA] WTB- 3.89 diff gears to suit borg warner diff
    By GTP 85 in forum Swap / Wanted to Buy / Trade
    Last Post: 31-05-2010, 01:23 AM
  3. !change of top speed in gears when fitting 3.7 diff gears.!!??
    By slappedvr in forum V6 Development And Modification
    Last Post: 30-01-2010, 09:54 PM
  4. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
