Hay guys just a question I own a 2006 ve ssv I've tried to hook up my iPhone 4 through the bluetooth and my phone wont find my car I've taken it to Holden and they said the the iPhone 4 is not compatible with holden just yet but the iPhone 3 will work since then I've tried to find my cars bluetooth with the iPhone 3 and that still won't pick it up so I dunno what I can do any suggestions? I've wondered if I go back to Holden and get them to hook the computer up to it mabye it could say if there's a problem with the Bluetooth? Cheers
You are following the instructions in your manual aren't you?
When connecting my Nokia, it would be a bit slow with picking it up, but finds it eventually
Try with another phone also, to make sure it isn't a dodgy Apple issue
My iphone 4 connects fine in my 08 SS. I do seem to remember there being a software update from holden that incorporated iphone issues a while back.
My Iphone 4 works perfectly with my 08 SSV too. Is your iphone up to date with its firmware/software updates? If not do that cos there has been many changes of late which address bluetooth issues.
My iphone 4 works perfectly with my 2011 SV6. Has done since May this year when I bought the car
My iphone 4 connects fine with my 07 ss
I had similar problem. My iPhone 3GS or any phone for that matter wouldn't connect so they ended up replacing the whole Bluetooth unit in the ute
My iphone 3G wouldn't find the car bluetooth, so tried the other way around, set the car bluetooth to search for my phone and that worked no problems. Worth a try...
Ohh ok then mate to easy since I've never used it what's the go for getting the car to search for the bluetooth how do you do that? Cheers bud
