Hey all
I got a 2008 ve and i bought some better and more powerful lights or globes but when i installed them, one side seems to be wider then the other and one side the projection goes futhur then the other.
On the stock h7 globes the bottoms are coloured black and orange and the new globes i purchased has a different style filament inside it aswell, does that mean one is for the left and the other is for the right side or it doesnt matter what side they go in ?
head lights are designed to have a wider rh spread and a longer lh projection, putting in them globes would of just multiplied or intensified that characteristic.
not sure but when i installed mine i put them in upside down and had the same problem where the beam was not projecting normally , try turning the globe around any hopefully that sould solve your problems.
How would you know if there upside down mate ?
And the globes i bought are 100w, same as this in the link
HOLDEN VE CALAIS OMEGA H7 BLUE HALOGEN HEADLIGHT GLOBES | eBay
but i believe i read somewhere on here that the 100w are no good as they can burn out your reflector headlights as when i put my hand over the headlights they are pretty hot.
i had my brothers ute parked next to me and i compared them. if there upside down you will see that there is a small gap around the housing and the globe will also be on a slight angle.
if it was really hard to put the clip back into place then its also a good chance that the globe was installed incorrectly.
Can someone comment on the globes i bought to tell me if they are good or not as i dont want to cause any damage from using these for a long period of time ?
They will fry the inside. Wouldn't go anything higher than stock, stick with 35W
How about the Phillips Diamond vision 12v 55w ? Would they be a safer option as I still want the white light with a bit of blue in them aswell.
Do these come in 35w or anything similar to these I can try ?
From all my research, the best bulb replacement is the Osram H7 Rallye 65w 2100 lumen bulb (factory bulb output is only around 1400 lumens).
I have ordered a set for parent's VE Berlina. I have posted in another thread regarding H7 bulbs. Once I install new bulbs, I will advise how much better they are for those interested.
Here's a link where to buy: Osram Rallye 65w Ultra High Output H7 Special-Service Bulb
Here's a link regarding bulb outputs (very interesting): Daniel Stern Lighting Consultancy and Supply
Here's a link to a thread regarding H7 bulb upgrades: Best H7 globes for VE headlights ?
Would these globes be ok?
NARVA Ultra Blue Globe - H7 12V 55W - Supercheap Auto Australia
Yeah, but that's damn expensive. If you're not in a rush, buy from eBay from the UK. They have much cheaper prices on headlight globes and generally faster postage than the US.
Yeah, I thought it was a bit expensive. Will have a looksy on ebay![]()
Any globe with a blue coating will actually give off less light. The colour temperature of the light may appear whiter, and this may be true, but there is more glare for oncoming vehicles and reduced actual light output is very significant.
If your into researching and reading technical documents, then click the link below relating to my post on blue globes.
Interesting
