Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Troy711
Thread: Spark plug change
    VE SV6
    Jan 2011
    Maitland
    Default Spark plug change
    Ok our SV6`s next service will involve changing the plugs. Can anybody recommend a brand and/or part numbers. Put NGK in our Aurion this week and think probally stick with them unless people say otherwise.
    Also whats involved is changing the plugs any gaskets needed,do the upper chambers have to come right off,any hidden bolts,special tool etc.
    Yes Im capable to do it myself and am doing so But its always easier if you know little tricks. I got heaps of tricks of the Toyota owners site to do the Aurion.
    Mick
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Nothing need to change plugs other than a ratchet, correct plug socket and new plugs, nothing needs to be unbolted (heatsheilds maybe?, I'm unfamiliar with VE) its just swap and go.
    Do one plug at a time so you don't mix up the leads. Check the plugs for carbon deposits, detonation etc. New car should be fine but it is always worth doing the check since they are there.
    Here's a link to what to look for, Spark Plug Diagnosis
    Ben
    There is no such thing as stupid questions, Only stupid people.
    VE SV6 ute
    Apr 2009
    vic
    you may need a torque rench. Look in the "how to" section, there is a guide on doing em.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Inlet manifold needs to come off.
    Then disconnect the 6 individual coil packs.
    If you've got an early model VE, you may need an inlet manifold gasket as they changed to a reusable one. Not sure of the specific breakpoint where they changed.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    If you need to change the inlet manifold gasket you might as well get some spacers from MACE.
    VE SV6
    Jan 2011
    Maitland
    Quote Originally Posted by Troy711 View Post
    Got a June 2008 model.
    But funny you should suggest this as read only the other night some one fitting these and thought oh heck for the price might put them on if the inlets gotta come off anyway ,nothing ventured nothing gained hey
    07 VE CALAIS V - V6
    Mar 2011
    Illawarra NSW
    I found the oem ones from the holden dealer as cheap as any others.
  1. VZ Spark Plug Change - Now Pinging???
    By bigdaddycool in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-08-2010, 08:23 PM
  2. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  3. Spark plug change V6
    By herkman in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-12-2006, 12:07 PM
  4. Spark Plug Gap???
    By markc3012 in forum V8 Development and Modification
    Last Post: 26-10-2005, 06:15 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
