Results 1 to 21 of 21
Thread: help! just bought a VE V
    VX acclaim S2
    Oct 2009
    Default help! just bought a VE V
    just bought a VE V 06 commodore. im looking to do something things to it pretty much straight away. it has the single exhaust, and im just wondering if i can get the dual exhaust out the back? and also i want to lower it on superlows and install subs through a line out converter so where do i tap into the speaker wires from?
    Firstly ill be doing the exhaust so if anyone could shed some light that would be good, i want the SS type with the dual exhausts with twin tips. some kits iv heard u can buy bolt on from cat back and allow this to happen, is that true? thanks
    kieran
    07 VE CALAIS V - V6
    Mar 2011
    Illawarra NSW
    I think you can buy the dual outlet inserts to change the lower section the rear bumper to suit dual exhausts then you can get a CAT back 2nd hand dual one for a V6 off evil bay and swap the rear mufflers to SS ones without major dramas except maybe for 'drone' of this setup on a V6 but each to their own.
    VX acclaim S2
    Oct 2009
    so am i after SS catback system? or v6 catback system?? and i want a bit of noise
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    VE ATOMIC SV6
    May 2011
    Mate you need to change the rear defuser to the sv6/ss ones which have the twin outlet. Personally to make the car look better id go the G8 defuser, but may be abit expensiver but usualy people with sv6/ss change their defuser to the G8 one.
    SV6/SS DEFUSER:Google Images
    G8 DEFUSER : http://www.google.com.au/imgres?q=ve...w=1024&bih=677
    BTW THAT BLACK CAR IS "BONNERS" CAR
    also the exhaust, you want the XFORCE 2.25 CATBACK SYSTEM.
    XFORCE TWIN 2.25" CAT BACK EXHAUST VE V6 COMMODORE SV6 | eBay
    then if you want more performance/louder you can get CATS+EXTRACTORS. but really dont need to
    Goodluck buddy
    VE SV6 ute
    Apr 2009
    vic
    hussy have you actually bought the xforce system yet? If not why are you recomending it?
    VX acclaim S2
    Oct 2009
    So after a twin defuser. N a system off a ss or sv6? Do I need any extra hangers or brackets?? And anyone know how the straight pipes go out the rear instead of muffler
    astroham is offline PHATV6
    SIDI sv6
    Jan 2010
    Penrith
    1: the straight through pipes ... have tried it and its very loud ... which is good ... but it is missing the tuned exhaust note and it drones like a mofo
    2:if you want a twin exhaust system you will need to buy a new rear diffuser like hussy said ... aparently the g8 ones aren't a perfect fir and there is a little bit of modification to get one on so keep that in mind ... the sv6 one should just bolt on
    3:i have the dual 2.25 x force catback system with quad tips on and it sounds good but it does temd to drone a little at certain speeds and revs ... i also have pacemaker extractors and hi flow cats on mine ...
    4:if you have a single system you might need some extra hangers for the back part where they spread out
    so that should some up everything ... i dont think there is much point in getting a standard ss exhaust because i think they will be to big ... i know the sv6 exhaust is already 2.25 ... but its not mandril bend ... so i hope thats helpfull
    VE Omega
    Nov 2010
    If you are going to put a ss/ssv/sv6 system on a omega you will also need
    2 Rubber Exhaust Mounts (22674119)
    1 Rear Exhaust bracket. (92066860)
    1 Left Hand heat shield. (92219526)
    1 Diff double exhaust hanger (92066857)
    SSV Lower bar inset (92173744)
    Pick them up from your dealer or holmart
    Check out my VE Commodore My Omega Mods
    VX acclaim S2
    Oct 2009
    VE Omega
    Nov 2010
    These are holmart prices
    1)#1 Rubber Exhaust Mounts (22674119) $11.00 each
    2) 1 Rear Exhaust bracket. (92066860) $22.00
    3) 1 Left Hand heat shield. (92219526) $39.00
    4) 1 Diff double exhaust hanger (92066857) $16.00
    5) SSV Lower bar inset! (For twin exhaust type) (92173744) $52.00
    holden dealer price is about $230 all up
    VX acclaim S2
    Oct 2009
    VE Omega
    Nov 2010
    07 VE CALAIS V - V6
    Mar 2011
    Illawarra NSW
    Quote Originally Posted by kizza50 View Post
    is there a holmart in melbourne?? or wil i have to go to holden dealer?
    But yes they are in Melbourne so you can collect and save on postage and delay in delivery. Holmart are not associated with Holden other than they source excess parts etc from Holden & HSV.
  15. #15
    VX acclaim S2
    Oct 2009
    ohh ye thanks for ur help! where in melbourne r they? also is the SSV defuser any good? i really dont want to modify the rear bar, but it says to specify which one? i dont get that part. also they do the twin exhaust pack for 350, will this give the car a nice note? compared to something mlike the Xforce 2.25" catback system?
  16. #16
    VE Omega
    Nov 2010
    the defusers are a little confusing by the sounds of things all SS/SV6/SSV diffusers fit after some modding, but as you don't wish to do that try this
    SIDI Rear Diffuser?
  17. #17
    VX acclaim S2
    Oct 2009
    its all confusing,,, lol i might just go to holmart and sort it out..see what they recommend
  18. #18
    VE Omega
    Nov 2010
    That would be good, when you find out please let us all know i have been considering doing this for a while
  19. #19
    VX acclaim S2
    Oct 2009
  20. #20
    VE Omega
    Nov 2010
  21. #21
    Hektic's Avatar
    Hektic is offline Donating Member
    2006 VE Omega Impulse Blue
    Jun 2010
    I bought myne from holmart, i went with the omega sidi difuser , str8 fit , the others you have to cut the plastic, still looks good and i got it with quad tips
    http://forums.justcommodores.com.au/...lue-omega.html
    Check Out my 2006 VE Impulse blue Omega
  1. Just bought a T/T VH SLE
    By saladine1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-10-2009, 05:14 PM
  2. just bought a VS
    By VS Grrl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2008, 10:27 PM
  3. Just Bought My First Car
    By mattwilson13 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2008, 11:46 PM
  4. Just bought a VZ SV6
    By *lebowski* in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-11-2006, 08:19 PM
