Hey guys has anyone put a ve ss wagon cat back exhaust on an berlina as it is a single exhaust, i read a few things but just want to make sure it will fit, it has all the mounts for a dual exhaust on the berlina.
Yes it will fit (as long as the passenger side has the mounting hardware). The Holden wagon and sedan (excluding the Statesman) use the same length system. Only thing I can see which may create some issues is whether or not there is a cut out for the muffler tips on the passenger side rear bumper.
Assuming you don't have that hardware this is what you will need
2 Rubber Exhaust Mounts (22674119)
1 Rear Exhaust bracket. (92066860)
1 Left Hand heat shield. (92219526)
1 Diff double exhaust hanger (92066857)
SSV Lower bar inset (92173744) or any other dual outlet lower bar insert for the ve
Check out my VE Commodore My Omega Mods
Cheers, i just got back from the wreckers and retrieved heat shield, exhaust bracket and the sv6 rear bar insert but the insert is to big, its off a sv6 ute so i don't know if the sadan inserts are smaller or?
yep you must get a sedan insert, how much did that set you back?
ohk then, was $40, just need the rubber mount just after the diff
Will do man
SS exhaust not on looks so much better, but just after the diff needs a hanger welded on but i don't know about welding on ve commodores as i don't have a serge protector and don't want to disconnect the battery because of the computer, any ideas?
Really? i don't think you need to weld anything. But if you do just disconnect the battery i do it all the time when hooking up lights and other things.
ohk then, i thought it ####s with the computer or something that's what ive been told but yeah
Well probs best to ask your mechanic or a dealer, but i would not hesitate myself.... could be costly if something got stuffed up.
Yeah will do man, yeah true cheers for the help with the exhaust man
i didnt think u needed to weld anything :S ?
i need to weld a new hanger where the white circle is
Interesting.... I just checked mine and it looks like yours.
dam, lol was hoping i could get away with not welding anything
Really dose not look like a big job, 30mins with a welder and you will be all set, or take it to an exhaust place.
Yeah was thinking just take it to exhaust shop and get him to smack it on 5 min job, just need to find a ss insert now ?
Or according to tinsnips "There is a dual outlet option for the omega available direct from holden - I think it's about 60 bucks from memory." may be simpler
ok ive figured it all out ill put some pics up, my dad picked this up its so ####ing simple i don't know why i didn't see it
The plate with the hanger is only bolted on so comes off easy so you can weld a hanger on the other side.
Well this would have been useful
E69 EXHAUST SYSTEM-V8 (L76/6.0Y); E69 EXHAUST SYSTEM-V8 (LS3/6.2W);. Fits: G8 | Nalley Buick GMC Brunswick
So you could have just picked up a "Diff double exhaust hanger (92066857) $16.00" from holmart
But well done man looks like you did a good job![]()
