Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By UFO
Thread: rear demister broken
    VE SV6
    Nov 2010
    Western Sydney
    Default rear demister broken
    Hi Guys
    Getting the tint done on the rear of my car cause there was little bit of fluff/hair on the window which has caused little bubbles, the tint that was on the car was of really bad quality and removing it damaged my rear demister only 2-3 lines work on the window.
    was told the only way to fix it was to replace the rear window(obrien quoted me $580 to replace the window) im not interested in spending that type of money to fix it as i am yet to use the demister.
    Has anyone used the rear demister repair kits you can pick up from jaycar, and how do they look from the outside?
    what are some good wreckers around western Sydney that I could get a rear window from?
    Thanks
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    its not just the demister, its the electronic aerial too. most people dont know that the radio has two aerials... the one that sticks out of the roof and the one splayed over the rear window in conjunction with the rear demister. very sensitive area to be playing around with (and costly if damaged).
    VE Omega
    Nov 2010
    2006 Sv6
    Nov 2010
    Quote Originally Posted by BigBoss View Post
    Really? a second aerial? for what use is it?
    im intersted to in what thats used for? when my tall aerial got stolen my radio was basicly useles?
    VE II SV6 - Alto Grey
    Apr 2011
    The rear demister repair kit has silver conductive paint in it. It does work, but it's a bitch to get the thin lines even when masking it up, and you have to clean any tarnish off the existing wires to get good contact. I'd go with this if there was only one or two repairs (check with a meter first). For more than this, I'd get a used screen from the wreckers...
    SSV Redline is offline You Ride I Ride
    VE Series II SSV Redline Sportwagon
    Mar 2011
    You have to think outside the box on this one, get a ho with big titties to rub her maps all over your rear window when it fogs up. Its cheaper, unless you plan on feeding and breeding. If so go back to plan A and replace the rear demister.
    UFO's Avatar
    UFO
    Oct 2009
    i was reading through my manual the other day (waiting for mrs as usual), and it mentioned that the rear window has an incorporated aerial along with the rear demister (in addition to the roof aerial). the radio then uses 'both' aerials to determine best reception and will use the one with the best signal. i'll have a look at manual tonight and post any more info, but definitely there. i know.... sounds weird, but if its in manual its gotta be accurate right?
    VE SSV Series II Sedan
    Feb 2011
    SA
    Quote Originally Posted by UFO View Post
    I know fords have this, but in my S2 mentions nothing
    Holden Commodore 2010 VE Series II SSV Sedan - Voodoo Blue: Icey's SSV
    My other little toy: Car Camera Recorder
    UFO's Avatar
    UFO
    Oct 2009
    Here we go:
    Page 1B-52 of manual.... "Diversity Antenna" (crap name ).
    The Diveristy Antenna improves FM reception under multipath conditions and is an integral part of the rear window assembly. The thin conductors that form the antenna are laid on the inside of glass in the same manner as the heated rear window elements. The radio receives signals from both the the diversity antenna and the conventional antenna. Internal circuitry within the radio decides which antenna is located in the cleaner signal area, and then uses that antenna for its radio reception. When the vehicle is in motion, the radio constantly monitors the inputs from both antennas and swaps between them in order to maintain the best possible reception.
    There's more.... but my fingers are already bleeding from typing so much .
    UFO's Avatar
    UFO
    Oct 2009
    Summarised....
    * If roof antenna is faulty or disconnected, radio may not use either aerial and poor reception will result.
    * Take care cleaning inside window bla bla bla
    * Dont put mobile phone antennas on rear window because of interference
    * NO Window tinting reccomended. Metalic significantly affects AM & FM bands, and normal dye based tint affects FM bands.
    No more typing, that's about it.
    Just to compare, my manual is (c)2009 for the MY10 VE. Print 2. Part# 92239592 (on back of front cover)
    VE Omega sedan 3.0 2010
    Feb 2011
    Fly Creek, N.T.
    thankyou UFO for all that typing. I live and learn: who'd-a-thunk an Omega would have two antennae ?
    Luke V8's Avatar
    Luke V8 is offline AKA Luke!
    VE Commodore SSV
    Feb 2011
    Go park your car in a rough area. wait for the rear window to be smashed. Call your insurance company and get it replaced for free ....
    VE Omega
    Nov 2010
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by Luke V8 View Post
    Free? My insurance is only free if it has someone to chase for money. When I reported a dent in a car park by an unknown person I had to pay the excess as there was no other party for them to get money from
  15. #15
    VE Omega
    Nov 2010
    Probably not the best idea then lol
    Check out my VE Commodore My Omega Mods
  1. Broken Hazard Light & Demister electronics
    By the_negro_puppy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2012, 10:21 PM
  2. Rear demister cause rear window to shatter?
    By gendi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2009, 10:24 AM
  3. Rear Demister Lug Broken Off, How do I fix??
    By markc3012 in forum Electrical Wiring / Questions
    Last Post: 23-05-2005, 06:15 PM
  4. Rear Demister Lug Broken Off, How do I fix??
    Last Post: 27-04-2005, 02:32 PM
  5. Broken Lug, Rear Window Demister ??Fix??
    By markc3012 in forum General
    Last Post: 25-04-2005, 01:07 PM
