Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Best HID ballast location?
    VE Omega
    Nov 2010
    Default Best HID ballast location?
    Hey all,
    Soon i will be installing HID lights in my projectors and am just wondering where is the best place to mount those balky ballasts on a VE? in my case i need to mount 4 of them. Oh and what are people using to hold them in place?
    Check out my VE Commodore My Omega Mods
    VE Omega
    Nov 2010
    VE SS UTE
    Apr 2008
    Fremantle, W.A
    have you purchased the hids yet?
    if not i just purchased some off ebay with a built in ballast to the dust cap much easier to install and no messy wires also looks untouched under the bonnet
    VE Omega
    Nov 2010
    VE SS UTE
    Apr 2008
    Fremantle, W.A
    yer its a complete product let me find it :
    HOLDEN VE COMMODORE HEADLIGHT H7 HID KIT SV6 SS SSV HSV | eBay
    HID KIT FOR HOLDEN VE COMMODORE FOG LIGHTS SV6 SS SSV | eBay
    the second one is for the foggies i just bought low beam and foggies from this seller and pretty happy with both of them so far and as said the fact that its plug and play and hidden after is what got my attention
    2007 VE omega
    Feb 2011
    perth WA
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    VE SS UTE
    Apr 2008
    Fremantle, W.A
    Quote Originally Posted by dredrum View Post
    Www.ezhid.com have 55w high beam in the same setup.
    This is what it looks like installed
    yer there the ones the high beams very bright?
    Quote Originally Posted by Troy711 View Post
    Are the WM foggies same as on the VE?
    almost positive its the same globes if you get a chance to check the ve ss foggies are H11's
    2007 VE omega
    Feb 2011
    perth WA
    Not my pic, got sent to me from Len at ezhid.com.
    I'm gunna do the upgrade ASAP though. Id assume a 55w is pretty darn bright!! I've seen them in spotlights, but that's a purpose built reflector. I'm thinking the standard high beam reflector will prob limit it a bit but will still be a helluva lot brighter than a standard halogen.
    VE Omega
    Nov 2010
    55w is off the chain mate, even in a reflector you will be blinding roos from 10km away lol, but be careful if you are running reflectors (not the SSV set up) you will also blind any oncoming traffic, so be quick to flick em back to your low beams
    2007 VE omega
    Feb 2011
    perth WA
    Yep deffo only a lonely country road high beam...just treat em like ya got spotties on the front
    VE SS
    Jul 2011
    Nowra
    Yeah i been thinking of getting some off ebay also...... Plug n play is the way to go...
    VE Omega
    Nov 2010
    Ok boys this thread got a little off track, I have already got the lights coming in the mail. So.... any suggestions for ballast locations?
    2010 VE SSV Wagon
    Nov 2010
    Aberglasslyn
    I fitted mine on the weekend and for a quick fix just cable tied them to other wiring harness at the front, can't really see where else to put them, but will look harder when i get time
    TELLING IT HOW IT IS SINCE 1982
  15. #15
    VE MY10 SSV Sportwagon M6
    Jul 2010
  16. #16
    VE Omega
    Nov 2010
  17. #17
    VZ 2005 Executive
    Jun 2010
    Perth, WA
    Are the HIDS built into the caps actually the same brightness as the separate ballasts? Are they just as good?
  18. #18
    VE Omega
    Nov 2010
    Thanks for bringing that up dingdong555 as they are not, unfortunately they are only 35wat as a posed to the current HID people are installing at 55wat
  19. #19
    astroham is offline PHATV6
    SIDI sv6
    Jan 2010
    Penrith
    well considering the ones i have with a seperate balast are 35 watt ... then they are equally as good i assume ... yes you can get the 55watt ... but in low beam thats just f'd up for other drivers
  20. #20
    VE Omega
    Nov 2010
    You won't be blinding anyone if you have projectors assuming the projectors don't melt out lol
  21. #21
    VZ 2005 Executive
    Jun 2010
    Perth, WA
    Quote Originally Posted by BigBoss View Post
    I thought people only install 35watt for the low beam and 55watt for high beam (even though high beam is stupid if you only flick them on/off as they don't have time to warm up.)
  22. #22
    VE Omega
    Nov 2010
    Hey dingdong555 flicking on and off still works coz the start up voltage is crazy high, ever see the amazing flash you get at the start?
  23. #23
    VE SV6 SERIES 2
    Jun 2011
    Kearns
    Does anything in the engine bay area need to be taken off before any of these HID kits are installed? I'm really interested in the plug n play design.
  24. #24
    VE Omega
    Nov 2010
    Not really i installed 35w high beams a wile back and it is real simple even with out the "plug and play design"
  25. #25
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    The 35W ones with the cap ballasts are just as bright as the 35W ones with external ballasts. These are the standard wattage that people use. 55W is generally only used in the high beams, even if you have projectors, you should not put 55W in.
    Flicking them on and off damages the bulbs. The high voltage spike at the start is to vapourise the salts in the COLD globe. If you turn them on when the salts are already vapourised it wears out the globes more quickly. But since you hardly use high beams the extra wear and tear from igniting the hot globes probably isn't an issue.
  1. Vs vin location
    By NALUTZ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2011, 09:40 AM
  2. vq vp bcm location
    By Krisp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2010, 08:59 PM
  3. BCM Location
    By dazza33 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2009, 09:23 AM
  4. PCM Location for VS?
    By Tomwally in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-05-2008, 11:06 AM
  5. Location
    By jafo in forum General
    Last Post: 24-11-2003, 08:36 PM
Tags for this Thread
