Hey all, quick question:
In engineering mode there's a function 'oil life'
Is this an accurate measure? Reason I ask is: My car's clicked over 5k and had an oil change at 3k, but oil life states 32%.
I first engaged engineering mode about a week after the services and it stated 40%
Sould I be worried?
Dont worry at all, 2k on oil is nothing it will be as good as new.
Sounds like it was not reset when your oil was changed. Do you know how to reset this yourself?
I am not sure if the "Oil Life" function is purely counting the hours the engine is running or smart analysis of the quality of the oil and what you are subjecting it to
Current Ride: 2011 VE Sedan - In Voodoo of course.
Last Ride: 2004 Subaru Liberty GT, Twin scroll turbo, tuned, Bilsteins, sway bars, no rice, 420Nm
Also Own: 1964 EH Wagon, modified interior, minor modifications outside
The Oil Life percentage reading is an algerithm messurement calculated on engine run time, rpm, etc etc....not completely accurate and not referred to in Australia. It would be reading low as it was not reset but....don't worry about it. It certainly does get its readings from analysis of oil.
I believe the procedure to reset the "Oil Life" is to press the accelerator to the floor completely and release. Do this 3 times in succession with ignition turned on and see if that works. Then it should reset and you have a starting figure to work with.
I believe its more a gimmick than a useful guide to follow. Just do the regular oil changes with good quality oil and don't be too concerned about the "Oil Life" readout.
yep.... doesnt actually test oil quality, just uses data from engine (run time, k's, revs, etc) to determine %. Dont rely on it, just rely on k's/time done like usual and you'll be fine.
Thanks all! Bit of a worry cause I paid for the oil and filter at the complimentary service 3 weeks ago!!!
It's a function that isnt used yet in Australia. I believe it's used over in the UAE.
Originally Posted by Reaper:
Originally Posted by Jecs:
... i had my car serviced at holden ... and when i asked them why they hadn't reset it no one ... and i mean NO ONE in the whole service center / dealership even new what engineering mode was ... so thats how usefull it is to them
