Results 1 to 12 of 12
Thread: Power Sockets
    2007 VE CALAIS V
    Jan 2006
    Default Power Sockets
    Is it just me or is it odd that this model of car only has one 12 power socket. It doesn't even have one in the rear.
    Does anyone know how I can get 12v from the boot area when Accessories is switched on with the ignition ? I want to be able to have it automatically switch off when the key is off/removed.
    Fekason is offline Fekason
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    Default Agree!
    I would be surprised if the optional boot 12V power outlet was live all the time, but can not prove it either way.
    I had the same concerns when I bought my MY09 SV6. To fix it, I bought the front and rear smokers pack from Holden (just over $100 from memory). That gives three outlets, and well distributed as well. The kit comes with good instructions and is not hard to fit. My only trouble was releasing the front wiring loom from its catch when I did not know how it operated.
    I took them out when I traded up to an MY11 SV6 earlier this month, and was pleasantly surprised to find that they slotted straight in to the new model.
    Remember that the Series II also includes a USB connection in the centre console to increase options.
    VE Omega
    Nov 2010
    I think the optional boot 12v outlet is always live but that is a simple fix with a relay
    Check out my VE Commodore My Omega Mods
    VE SSV Series II Sedan
    Feb 2011
    SA
    The boot one is allways live... Holden even told me that it wasent until i pulled the manual out on them
    Holden Commodore 2010 VE Series II SSV Sedan - Voodoo Blue: Icey's SSV
    My other little toy: Car Camera Recorder
    VE Omega
    Nov 2010
    VE SSV 60th Ann
    Oct 2010
    I installed the optional socket in the boot myself. Comes with a connection that simply plugs into a socket inside the rear trim and you are good to guy. Couple other little bits to add but really easy. I think I paid $20 for the part. Saved heaps on what Holden wanted for supply and fit
    Bonners White E3 Clubsport - SV Enhanced
    Wortec Brakes Distributor
    VYII Berlina 3.8, VE Calais V 6L
    Aug 2005
    I have the optional plug in the boot, and yes its live all the time. I leave my Holden fridge in there when the car is off and it has never flattened the battery, all though from what I understand, the fridge leaves enough power in the battery to start the motor.
    VE II SV6 MY11 Sedan
    Jan 2012
    Central Coast
    I've searched under the trim, I can't find the plug point in any wiring where I could install the 12v socket. Can anyone give me a heads up as to where it is? I thought it might be on the side close to the battery, but just couldn't seem to find it. If there is no actual plug, can anyone guide me on which wires are the best to jump off?
    Thx, Dave
    (SV6 Series 2 Sedan MY11)
    VE SSV 60th Ann
    Oct 2010
    Here is the pdf instructions that come with the genuine article
    http://philcampbell.customer.netspac...%20fitting.pdf
    Also, have a look at this thread
    VE Boot Power accessory socket - Pic wanted - Page 2
    Jan 2012
    Central Coast
    VE SSV 60th Ann
    Oct 2010
    VE
    Mar 2011
    n
    Quote Originally Posted by kyone View Post
    It's not just you, and it is odd.
    Prediction: In about ten years time, the commodore will have front & back outlets, probably even USB power. It might even have more than 2 cupholders.
    But you will have to wait ten years.
    HIDs.....LEDs..... DRLs..... CHEV Badges..... ->
  1. VT tail light sockets
    By Warface in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-05-2010, 09:31 PM
  2. 12 volt sockets
    By hatzi2508 in forum VE Holden Commodore (2006 - ?)
    Last Post: 05-12-2009, 04:55 PM
  3. Installing additional power sockets for accessories
    By Calaber in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-09-2009, 09:59 PM
  4. VY head unit sockets
    By ris00 in forum Car Audio
    Last Post: 02-11-2006, 09:31 AM
  5. What bulb sockets do commodores use?
    By venomous in forum Electrical Wiring / Questions
    Last Post: 15-08-2006, 10:45 PM
