Results 1 to 11 of 11
Thread: Help!!! Urgently!!!!
    VX acclaim S2
    Oct 2009
    Default Help!!! Urgently!!!!
    Just tried to install my sub with a loc, tapped into the speaker wires Help!!! Urgently!!!!-imageuploadedbytapatalk1311999017.147380.jpg
    Ran my RCA leads down n found power under the plug with the speakers so used that for a remote, turned the car on, and it's giving me abs ESP and airbag faults.. What did I do wrong and how can I fix this???
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    sounds like you may have hooked up to some wrong wires?
    where exactly did you tap into the wires? on the drivers side of the headunit?
    did you remove the seats and turn the car on while they were out?
    only way to fix it will be to check your wiring, fix anything thats wrong there, then take the car to holden to get the errors reset, and hope they clear, and you havent stuffed anything.
    VX acclaim S2
    Oct 2009
    I can't even start the car anymore an I tapped into the plug on the drivers side and those r the wires iv been told... What can I do???????? I didn't cut any wires, only splice
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    VX acclaim S2
    Oct 2009
    Plug out of the Headunit on the left ottom drivers side headunit, i took my loc out and it starts and works again and no faults can anyone tell me the correct wiring for front speakers on a ve v?
    VX acclaim S2
    Oct 2009
    Well there are 2 light green wires and I hooked in the wrong one..... Oppsss, just tried the other one and all good no faults, no lights on the dash subs pumping me smiling
    astroham is offline PHATV6
    SIDI sv6
    Jan 2010
    Penrith
    VZ Crewman L76 M6 & Calais V L76 S/Wagon
    Aug 2007
    NSW
    Yep VE's very sensitive in that dept. reason I bought what I did!
    MC
    VX acclaim S2
    Oct 2009
    1996 VS BT1 SS 5ltr original
    Apr 2008
    lol.... i loved the ending on that one as the start of the post was someone having a heart attack..
    VX acclaim S2
    Oct 2009
    Quite a scary thing hearing ur car tell u ur cars stuffed and doesn't crank lol
  1. need help urgently
    By weedo_86 in forum V8 Development and Modification
    Last Post: 02-02-2008, 04:11 PM
  2. need help urgently
    By turbobt1 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-03-2007, 07:46 PM
  3. Need Help Urgently!!!
    By donz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2006, 11:14 PM
  4. WTB Urgently
    By hsvd_g in forum Swap / Wanted to Buy / Trade
    Last Post: 26-07-2005, 09:03 PM
  5. WTB:Urgently
    Last Post: 25-07-2005, 11:44 PM
