Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By pjdm1980
Thread: How do you replace aerial base on a rear roof mount aerial?
    VP Berlina
    May 2006
    Default How do you replace aerial base on a rear roof mount aerial?
    Hi.
    I have searched hard on the web on how to remove the aerial base on a rear roof mount aerial and can't find anything. Would one of you know how to do this? Reason I ask is I'm looking at buying a 2008 SSV wagon and the aerial has suffered some sort of impact, the aerial has snapped off and the base mount has lifted from the roof approx 2-3mm. Apart from that the car is in pretty good shape. Don't necessarily need to replace with the same aerial. Would really appreciate any assistance.
    Thanks.
    Steve.
    Supe's Avatar
    Supe is offline Supe
    VE Calais 6.0
    Jan 2008
    Rural NSW
    I broke mine a couple of years back and if I remember right they had to remove the interior roof lining to get at the base.
    VP Berlina
    May 2006
    That definitely sounds like something for the professionals!!! Is it something you take to Holden to do or are there other companies out there that do this? I imagine Holden would take your daughters left arm to do such a job. By the way I live in Melbourne. Thanks for your feed back.
    Steve.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Bit of a prick you pull the lining down at the rear and reach in to undo a bolt and the plugs to release the base.
    Bit like working in the dark as you cant see what youre doing.
    Silver Certified.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Quote Originally Posted by Supe View Post
    I remember your thread, makes me think twice every time that back out of the garage!!!
    Supe's Avatar
    VE Calais 6.0
    Jan 2008
    Rural NSW
    Wow PJDM I can't believe you recall that, it was so long ago.
    I am still really grateful to the guys at Holden that fixed my mishap including the paint-less dent removal, and now I reverse into the shed and then drive out, if I still hit the door doing that I don't deserve to be on the road lol.
    VP Berlina
    May 2006
    Thanks guys for all your feedback, really appreciate it. Being such a nice car I think it's best to get the pros to do it. Called Holden today and purchased the mount $116.60. Going in tomorrow morning to get a quote to have it installed. At least this way it's done properly and should finish like new. Gee these 6 litre engines have some get up!!! Such a pleasure to drive. Looking forward to a 3" exhaust and cold air intake. Mmmm mmm. Will let you know how I go with the repair.
    VP Berlina
    May 2006
    Hi guys.
    The aerial is all fixed. Took 2.5 hours to do and the job turned out great. Fortunately only needed to remove the trim off the tail gate to access the base mount, which was quite easy to remove and he repaired the damage to the surrounding metal pretty much like new. Repairer was "Repair a Dent" from Melton in Victoria. Highly recommended. 1300 336 873
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Didnt realise it was a wagon, my instructions were for a sedan.
    Silver Certified.
    Supe's Avatar
    VE Calais 6.0
    Jan 2008
    Rural NSW
    Same, I assumed Sedan which is a lot more annoying to access. Glad it worked out for you.
    If you want to feel better you can read my thread here when I bent/tore my rood mounted antenna by backing it through the roller door.
    VE Roof mounted antenna, a cautionary tale...
  1. Ve aerial & base help
    By OMEGA07 in forum VE Holden Commodore (2006 - ?)
    Last Post: 18-04-2011, 07:37 AM
  2. How do you replace a Aerial
    By VL'NZ in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-05-2010, 08:01 PM
  3. best place to mount CB Aerial on a VT commodore thats wont be a messy dyi
    By cds in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-07-2009, 12:46 PM
  4. No car aerial, how / where to replace?
    By dale1389 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2008, 04:17 PM
  5. How Do I Replace An Aerial On My VN Calias?
    By Kall911 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2005, 07:16 PM
