Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Like Tree2Likes
Thread: Exhaust Falling Apart :(
    Ve Sv6
    Sep 2008
    Shepparton
    Thumbs down Exhaust Falling Apart :(
    Just a question i have a 2007 SV6...and after coming home from a long trip i noticed out of the left side exhaust tip what looked to be a blond wig stuffed in my tip...after pulling it out i realized it seems to be fiber glass since my hands go all itchy....as I'm pretty sure my engine doesn't eat blonde women would it be safe to say the rear left muffler is falling apart in side or the center/cats etc....it is an aftermarket exhaust i had put on it custom made at my local shop so its not xforce etc...it's probably been over a year since i had it done would it be worth going back to the shop about it????
    bladerunner's Avatar
    bladerunner is offline AUSTRALIAN MADE AND OWNED
    VE SS UTE
    Nov 2010
    brisbane nth
    yep,definately,it sounds like the baffle has come away that runs thru the muffler. grab a torch and have a look up the pipe you'll soon see if thats the case
    im out of my mind at the moment...please leave a message
    2012 S2 SV6 Sedan
    Apr 2010
    Its just the insulation inside the rear can. I doubt the internal structure is letting go (seeing is should be welded metal) however it seems odd to have the fiberglass wadding make its way out the exhaust tips, then again stranger things have happend... Do you notice any difference to the sound of the rear muffler?, like droning or a ratterling sound.
    In the end if the exhaust is only 12months old take it back and get them to check it out.
    If your not living life on the edge, then your taking up space!
    Ve Sv6
    Sep 2008
    Shepparton
    It was weird pulling it out the tip lol...sound wise i think it's almost the same maybe a smidgen louder but id need a db meter
    2007 VE Lumina
    Apr 2011
    Maybe, for lols, someone decided to stick the fibreglass UP your exhaust.
    Ve Sv6
    Sep 2008
    Shepparton
    Well that's what i thought to start with someone being a comedian heres a few pics i just took this is whats left i cant get my hands down that far
    Attached Thumbnails Attached Thumbnails Exhaust Falling Apart :(-31072011036.jpg   Exhaust Falling Apart :(-31072011035.jpg   Exhaust Falling Apart :(-31072011034.jpg   Exhaust Falling Apart :(-31072011037.jpg
    VE SS UTE
    Nov 2010
    brisbane nth
    Quote Originally Posted by IGNITIONSV6 View Post
    looks like condensation has completely rusted out the perforated section that runs thru the muffler, looks farked alright but on a 12mth old muffler? but as hexem said- stranger things have happened..
    Ve Sv6
    Sep 2008
    Shepparton
    2012 S2 SV6 Sedan
    Apr 2010
    I'd be putting the factory mufflers back on soon. If it is blocking the exhaust gasses from escaping it could cause you some problems.
    Ve Sv6
    Sep 2008
    Shepparton
    VE BERLINA 07
    Jan 2011
    Rowville Melbourne Vicotria
    Yeah only problem is i sold the stock mufflers (Dammit)
    since u sold it go back n crack coz im sure this has never happened to any1 (well ive never heard of it b4) and im sure ur car didnt have a bolnde for dinner
    this might damage ur engine or just un bolt the end mufflers off and see whether it goes deeper than that
    I'm a boy who appreciates a good body, regardless of the make.
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    Quote Originally Posted by HEXEM View Post
    yep, stuffing coming out of the pipe tells me two things.... poor manufacture quality and more restricted air flow because baffle isnt in place properly.
    if you havent got stock mufflers anymore, I'd be going back to place that sold you this custom crap and asking them to replace/repair it. failing that, buying BETTER QUALITY mufflers from elsewhere.
    but definitely remove this crap. looks shait, is shait, and isnt doing your car's fuel economy any favours.
    Ve Sv6
    Sep 2008
    Shepparton
    Yeah ill be going back to them 2moro to get a please explain/fix....he did say they made the diameter a little smaller at the rear where the gases are cooler to try and stop drone but it appears this has only created a bottleneck
    Ve Sv6
    Sep 2008
    Shepparton
    Well car is booked in for 2moro to replace the mufflers or just to put a whole stock system back on is the question i cant afford to be replacing an exhaust every ####ing year
  15. #15
    RUF-60L's Avatar
    RUF-60L is offline Donating Member
    2008 VE SS
    Nov 2010
    different brand mufflers?
    Quote Originally Posted by dingdong555 View Post
    Be careful not to hit yourself in the head whilst pulling
    My Ride, RUF60L
  16. #16
    Ve Sv6
    Sep 2008
    Shepparton
    well i really duno which option is the best or which will work out cheaper if they have a stock system laying around.......... at least the car will be quiet again
  17. #17
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    A mate had the same thing happen to his VX SS was the stock exhaust but was eight years old when it happened. Is you car on gas because it looks like a lot of moisture has been building up in your exhaust system, so I'd be pulling it all apart and checking the whole system.
  18. #18
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    Only seen this happen once. Turned out it was thanks to him letting his kid wash his car and fill the cans up with water each week by stuffing the hose in there. nice.
  19. #19
    Ve Sv6
    Sep 2008
    Shepparton
    Nah not on gas......hmmmm the i do wash my car a lot but i defiantly don't stick a hose up there when cleaning
  20. #20
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    I wash mine a lot also - you'd need to be pretty reckless to fill the cans up.. Just don't angle the hose into the pipes on a VE and you should be fine.
  21. #21
    Ve Sv6
    Sep 2008
    Shepparton
    i usually don't hit them with the hose anyway...as they are full stainless steel i usually rub them to polish them up lol
  22. #22
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
  23. #23
    VE Commodore International 2009
    Jun 2009
    Shepparton
    IGNITIONSV6
    "Yeah only problem is i sold the stock mufflers (Dammit)"
    Ill sell them back to you, Double the price?. They are working well LOL
  24. #24
    VS V8 Manual
    Jun 2011
    NZ
    just cut them off and put on a diff dumper.. problem solved
    VS V8 Manual ... Reppn it for NZ
  25. #25
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The mufflers should have a 2 year warranty, if not, then they were poor quality to begin with. You should only have to pay for the labour to have them replaced.
    Visit my Facebook page
  1. VR whole roof falling down
    By maroon in forum General
    Last Post: 12-09-2008, 08:09 PM
  2. Help VN and me falling apart
    By aletakmoore in forum General
    Last Post: 10-08-2008, 01:03 AM
  3. Boot falling Down
    By LindasBT1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-03-2006, 03:04 PM
  4. Help My Vt Is Falling Apart
    By dragrat in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-07-2004, 07:47 AM
  5. Paint falling off
    By midnight.outlaw in forum General
    Last Post: 15-06-2004, 10:42 PM
