Results 1 to 10 of 10
Thread: VE in dash diagnstics
    2011 SSV Ute
    Aug 2011
    Moura
    Default VE in dash diagnstics
    Hi, does anyone now the sequence of buttons you have to push to get into the fault codes etc on the VE?
    With My VZ you pressed the Mode/Set button while turning the key on......
    This would give you access to a few things, like volts, exact fuel, any error codes, a dash test screen..........
    Anyone know?
    VE Omega
    Nov 2010
    Try this it is called "engineering mode"
    You can get to the engineering mode by holding down the left "channel change" button on the steering wheel when starting your car -- off to on
    this comes from "affinity"
    Check out my VE Commodore My Omega Mods
    astroham is offline PHATV6
    SIDI sv6
    Jan 2010
    Penrith
    i dont think you can get error codes that way though ... because when i asked holden about engineering mode no one knew about it ... and if the error codes were there you would think someone would have known about it
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    VE S2 SS Sportwagon
    Jan 2011
    Quote Originally Posted by StoneX View Post
    You need to plug in a scantool for error codes.
    +1 exactly
    HM/Perry headers, CATS and 2.5 " exhaust.
    OTR
    Tune
    VE Omega
    Nov 2010
    Or... you can do what i have done and get a obd2 to USB cable plug it in to a computer fine some appropriate software and there you go, you will have every thing. total cost about $30 if you already have a laptop
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    VE Omega
    Nov 2010
    Yep ebay is they way to go, something like this should do it
    Car Code Reader OBD II OBD2 to USB Interface | eBay
    I use a macbook so i use a program called "Movi Pro" but if you use a windows computer there are lots more programs, just google it.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    VE Omega
    Nov 2010
    Haha yep i payed like $20 for mine
  1. VK Calais digital dash to analog dash
    By mattw in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-12-2008, 08:16 PM
  2. Replies: 2
    Last Post: 02-11-2005, 07:10 AM
  3. standard vh dash 2 sports dash
    By pjn963 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-08-2005, 02:13 AM
  4. Changing a VP standard dash to a Tacho Dash
    By Madhouse_Dave in forum Electrical Wiring / Questions
    Last Post: 01-07-2005, 11:35 AM
  5. Custom Dash + Coloured Dash Lights?
    By ViperVp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2005, 09:08 PM
