Results 1 to 25 of 25
Thread: Bad engine missfire VE SS L98
    2012 S2 SV6 Sedan
    Apr 2010
    Default Bad engine missfire VE SS L98
    Deleted Post!
    If your not living life on the edge, then your taking up space!
    VE Commodore SS Thunder Ute
    Jun 2011
    Moree
    My suggestion....buy a Series 2 but I'm pretty sure we've had this conversation
    2012 S2 SV6 Sedan
    Apr 2010
    Deleted Post!
    VE SS SEDAN
    Dec 2008
    Central Coast
    Would love to no what it is as my car has similar issues sometimes. I havent had the o2 sensors checked but half my plugs were really black and the other half not so black are urs the same>
    06 VE SS
    May 2009
    Rockingham, WA
    2012 S2 SV6 Sedan
    Apr 2010
    Deleted Poat!
    2012 S2 SV6 Sedan
    Apr 2010
    Deleted Post!
    Series II SS
    Jul 2010
    Hi Hexem,
    Sorry to hear your having more troubles still, Is there any chance due to what you have had occur with your car that you could be entitled for another new engine
    but a series 2 manual version, this would either solve the problem or show the car has potentially other issues other then directly engine related?
    good luck mate
    IF YOU BUILD IT THEY WILL COME.... STILL WAITING LOL
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    ive replaced 3 sets of lifters on L98's under warranty, but that was due to them ticking for 10 minutes after cold startups... id like to know how they inspected and cleaned the O2 sensors.... last car that came in with your symptoms left with 2 new cats and 2 new O2 sensors cos the LH bank sensor 1 failed and overfueled the engine, which melted the converter and blocked the exhaust. and by the sounds of it, your has been overfuelling because you have a rotten smell from the exhaust
    06 VE SS
    May 2009
    Rockingham, WA
    Quote Originally Posted by HEXEM View Post
    Well if you know who's keeping the good ones let me know because I've had 3 of them in my car and they have all suffered bad valvetrain clatter/clunk/rattle. $50k on a new model car which sounds like a 1970's v8 with the k's to match.
    Oh i was not having a go or anything mate.The odds of having 3 new engine must be out of this world,but it could just bad luck.Anyway if you do find out whats up lets us know.you've got me interested now.
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    2012 S2 SV6 Sedan
    Apr 2010
    Deleted Post!
    2012 S2 SV6 Sedan
    Apr 2010
    Deleted Post!
    2012 S2 SV6 Sedan
    Apr 2010
    Deleted Post!
  15. #15
    Boonz's Avatar
    Jul 2005
    Boonz,
    Funny you mentioned about the cats etc. I asked them today had they take the exhaust off at the cats and inspected them to see if they had collapsed. Their reply was no.
    How they cleaned the sensor? got me... They said that the smell is due to unburnt fuel entering the CAT. They did get an error code on the first day which indicated LH bank sensor problem but as they were driving it it cleared itself without the need to reset the DTC using Tech2...
    I'd like to know why all of a sudden the car desides to overfuel the CAT? The car felt normal on the way home last night and idled smoothly at the lights. Then this morning the problem was back.
    As for the lifter problems I've had replacement camshafts, lifters and finally a new 3/4 motor fitted, which has only lasted 8,000klm before it started rattling its head off in the mornings for several minutes... Ive posted links to my video recordings in another thread if you want to hear it.. Now I am going through the same shit again.
    BTW have you had lasting success once the new lifters were fitted? I never seemed to have them last more than 1,000klm before rattling again.
    overfuelling is caused by O2 sensors giving the ECM incorrect readings, the cat converters on these cars seem to be very easy to destroy unfortunately.
    as far as im aware you cant clean or inspect an oxygen sensor... if its under warranty the sensor and cat gets replaced at the same time usually. id be asking for the exhaust to be inspected thoroughly before they replace anything else.
    im pretty sure if the 3/4 motor has the same symptoms as before after the service fix then your entitled to a new long motor assembly...
    as for the lifters ive replaced before, all cars have done over 20,000 k's now and havent had a problem, one car had to have a new oil pickup and pump fitted before i changed the lifters because the pressure at idle was lower than spec, might be something worth getting checked out first
  16. #16
    2012 S2 SV6 Sedan
    Apr 2010
    Deleted Post!
  17. #17
    Commodore
    Jun 2004
    NSW
  18. #18
    2012 S2 SV6 Sedan
    Apr 2010
    Deleted Post!
  19. #19
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Sounds like poor diagnosing to me have you considered trying another dealer?
    Running rich could be due to a faulting o2 sensor or the o2 sensor code could just be the o2 sensor saying hey too much fuel!!
    One injecter staying open would definately cause a rich mix and rough idle as there would be too much fuel for the plug to spark therefore a constant missfire on that cylinder. if the injector itself is fine it could be an ECU issue.
    Silver Certified.
  20. #20
    2012 S2 SV6 Sedan
    Apr 2010
    Deleted Post!
  21. #21
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
  22. #22
    2012 S2 SV6 Sedan
    Apr 2010
    Deleted Post!
  23. #23
    2012 S2 SV6 Sedan
    Apr 2010
    Deleted Post!
  24. #24
    vesv6 commodore2007
    Aug 2011
    Hi, same with my sv6. did you get it under warranty? or did you pay? also how much did it cost to fix.
    mines done 80000
  25. #25
    2012 S2 SV6 Sedan
    Apr 2010
    Deleted Post!
  1. vs ss seems to missfire??
    By sik ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2011, 05:25 PM
  2. vy missfire
    By tassiehunter in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-02-2011, 04:00 PM
  3. missfire
    By andy_man343 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-09-2010, 11:50 PM
  4. Vn Missfire
    By jetoblaster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-09-2008, 08:24 PM
  5. Vs Missfire
    By Chris Everett in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2004, 05:56 PM
