Results 1 to 8 of 8
Thread: Charging battery
    VE SSV 60th Anniversary
    Feb 2011
    Alice Springs
    Default Charging battery
    Being a new VE owner and noticing that the battery is in the boot.
    I have a Ctek battery charger which I occassionally hook up to top up the battery and also use while I am on holidays.
    Would it be ok for me to wire up the permanent connectors to the underbonnet jump points to charge the battery now?
    VT
    Apr 2005
    QLD
    Do you really need to top up the battery all the time?
    If your battery and charging system are in good nick, is it really necessary
    5L VH/ V6 VE
    Nov 2009
    geez left my car sitting for 2 months, hit the key and it fired.
    I would suggest a new batttery if it regulary needs topping up
    VE SV6
    May 2011
    Newcastle, NSW
    I'm assuming if he's on holidays he's obviously using the battery while the car isn't on? Batteries don't exactly last forever like that... lol
    My battery has decided to give up on life in the last couple of days. Does anyone know if the NRMA battery replacement service any good? Or what type of battery should I be looking at and where to get it from... I don't really know anything at all about batteries.
    vx s pack II
    Jan 2010
    aLKIDA
    Every time i charge a battery a always take the earth of the battery so there is no possible way to burn out any electronics.
    The way you are going to be doing it will have the battery still connected. I would not do it with any charger.
    It is safer to do it with the earth off.
    2007 VE Lumina
    Apr 2011
    Disconnect the battery, and remove it from the car before going on holiday...
    VE
    Mar 2011
    n
    Yes, the worst that can happen is that you will waste electricity.
    The battery doesn't like to run flat, but unless it's up on bricks, and never started - it definitely doesn't need continual charging.
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    You have a ctek charger, just hook it up to the battery and be done with it. No need to disconnect with those chargers either.
  1. VN V6 not charging
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-06-2010, 07:32 PM
  2. Battery/Charging Issue
    By mattman in forum Electrical Wiring / Questions
    Last Post: 22-02-2010, 11:36 AM
  3. totally dead battery, charging questions
    By pow3rslave in forum General
    Last Post: 13-07-2009, 09:57 PM
  4. charging a battery
    By cladiges in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2007, 09:53 PM
  5. Charging battery 1997 VT
    By Ian J in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2005, 08:13 AM
