Results 1 to 19 of 19
Thread: Red LED break lights?
    VE Omega
    Nov 2010
    Default Red LED break lights?
    Hey all,
    I have ebay ssv tail lights and they look pink!!!
    To fix this i was thinking of replacing the bulbs with red LED lights but i have a problem.... the stock bulbs have 2 filaments and I'm struggling to find LEDs that have this duel function. Any suggestions?
    Check out my VE Commodore My Omega Mods
    Commodore
    Jun 2004
    NSW
    brgsv6's Avatar
    brgsv6 is offline Bing!
    VE SV6 M6
    Jul 2011
    Blue Mountains
    VE Omega
    Nov 2010
    Thanks for that Xonar :-)
    Oh and brgsv6 how would a LED achieve this effect?
    VE Omega
    Nov 2010
    Dose anyone know the name/model of light used as the break bulb?
    Johnsy's Avatar
    Johnsy is offline ★★★★★
    HSV R8 LS3
    Oct 2005
    C/Town
    Luke V8's Avatar
    Luke V8 is offline AKA Luke!
    VE Commodore SSV
    Feb 2011
    Quote Originally Posted by BigBoss View Post
    Hey all,
    Non Genuine i'm assuming?
    Just answered my own question - you have an omega
    VE Omega
    Nov 2010
    brgsv6's Avatar
    VE SV6 M6
    Jul 2011
    Blue Mountains
    Any brake light led should work
    VE Omega
    Nov 2010
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    Find out what the bulb type is. eg symmetrical pins, or offset pins, and dual contacts, single contacts etc. Then go hunting. I always use the site superbrightleds.com
    I haven't done my brake, reverse or indicator lights, but I have done everything else on my car with bulbs from this company. Always remember to match the led bulb colour to the same as the lens colour that its going into.
    Here is a link for the bulbs that will be the brightest etc, but you need to check your bulb type;
    BA15 Dual & Single Contact High Power SMD LED Automotive Bulbs
    1156 White Bulb Brightness and Price Comparison - Super Bright LEDs
    More info here;
    LED Vehicle Bulb Finder
    Super Bright LEDs - Conversion to LED Car Bulbs
    VE Omega
    Nov 2010
    VE Omega
    Nov 2010
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    How do the new bulbs look?
    I have just ordered my LED bulbs for my VZ Calais. They are also the 1157 base but I got the brightest available, although they cost quite a bit more. Link below;
    45 High Power SMD LED 1156/1157 Tower Bulb Specifications
    Have you got pics of your lights before and after?
  15. #15
    VE Omega
    Nov 2010
    It is a little hard to show but yes they look much better, conventional in left LED in the right
    It looks like your new lights will blind the gods!!!
  16. #16
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    Nice work. It's good to see that you are happy with the outcome.
    I have been wanting to do a rear tail light conversion to LED for a while. Was waiting for a decent bulb to come out. I will post some pics up when I receive my set from America.
    I am not necessarily after more intense light, although it most likely will be more intense/brighter, but I want a vivid red tail/brake light and not a slight pink light which it is now, which is due to UV light fading the lenses ever so slightly over the life of the car.
    Anyone else doing this conversion, also make sure you do the same and use the same LED bulb colour as the lens which its going behind.
  17. #17
    itsArthurKomar is offline sexy beast
    super awesome time machine
    Apr 2011
    ya asss
  18. #18
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    I have just done my rear end LED bulb conversion on the tail/brake lights and the reverse lights. The globes I purchased were from superbrightleds.com
    These are the brightest globes available. I have to say that the original slightly red faded lenses with yellow bulbs that give off a slightly pink tinge is totally gone. The new bulbs are absolutely amazing. They are maybe slightly brighter although very similar in light output, but they are so vividly red and give perfect illumination throughout entire light.
    I also did the reverse lights. These are just as amazing. For those wanting the most light at the rear when reversing for such a small outlay of money, then I would recommend these bulbs. Not only are they bright, but the pure white light compared to the original yellow is amazing.
    My whole car from the inside to the outside is all but fully converted from old yellow bulbs to high powered LED/SMD bulbs.
    I did take some pics when I had only done one side at the rear, but the camera really does lie and does not give a true indication of change. So I won't post any pics.
    All I will do is post a link to the bulbs that I got and say that everyone should get them.
    $24.95 each bulb and approx $40 postage to me in WA.
    Make sure you choose the red bulbs for the tail/brake lights in the red lenses, and in clear reverse lenses, choose the cool white.
    Any questions for me as to exact bulb or any LED question in commodores then just ask. I have done alot of testing and have learnt alot.
    Regards
    Matt
  19. #19
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    For those who requested pics from me, here they are. Pics of lights can be deceiving. If the camera lens is left open slightly longer, then if leads you to believe the lights are brighter than they are. This is why I have posted a few below so you can see the difference mainly in the colour and not necessarily the brightness.
    The right hand side (in every picture) has been modified with the new LED stop/tail light bulb and also the reverse bulb. Also the high rise brake light has a red LED installed;
  1. HELP NEEDED VX all 3 break lights not working
    By phelan83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-02-2010, 04:43 PM
  2. Vs commodore, how do i get too the globe ib my break lights
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2009, 01:08 AM
  3. break lights too bright
    By System in forum Electrical Wiring / Questions
    Last Post: 17-11-2008, 09:45 PM
  4. VT break light connected to the dash lights?
    By VT-Prime in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-11-2008, 09:10 PM
  5. break pads? price? vt break conversion?
    By stock_vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-09-2005, 06:02 PM
Tags for this Thread
