Page 1 of 2 12 LastLast
Results 1 to 25 of 43
Like Tree1Likes
Thread: ve calais burning heaps of oil..
    calais06's Avatar
    calais06 is offline Donating Member
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Default ve calais burning heaps of oil..
    Hey,
    I bought my 2006 ve calais a month ago from a dealer, who did a service + filter (i checked oil, and was new when i picked it up). They were reluctant to stamp the log book, but i got them to.
    It had 86,000km when i bought it, it now has 91,000km, mostly highway driving and the oil was almost fully empty, took over 5L of oil..
    Took off the intake and there is some old oil sitting on throttle body+ inside of air intake.
    Any ideas what this could be? Any ideas?
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    i suggest you take it back to where you bought it. if you have used 5 litres of oil in 5000 KMs something is VERY wrong. how long was it driven low on oil? was it making bad noises? i would assume being run with such a low oil level has done some damage.
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Im not sure, I hadnt thought to check it cos the service interval is 15,000km and i've had it 5,000km (a month), only noticed a small noise when cold on startup, otherwise it seemed/seems fine.
    Calling the dealer tomorrow.
    Thanks.
    VY SS
    May 2011
    Auckland
    Oil venting back to the intake isn't that uncommon, usually the breather hose off the rocker cover.
    I'm surprised it ran when it needed 5l of oil! That must have done damage. Did they tighten the sump plug?
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Ok thanks, i saw that tube from the rocker cover, the bit that got me worried was how the oil got there if it was running so low.
    Well i havent seen any oil leaks at all, thats the odd thing, im checking/recording the level each time i drive and kms now.
    Calling the dealer and seeing what they say
    VE International 3.6L
    Jun 2011
    Gold Coast.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    You sure they even serviced it? Did you check the level after you picked it up?
    Edit: I see you did.
    Theres definately no leaks?
    Silver Certified.
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Yeah it was overfull when i got it (oil).
    Just put penrite 10w/50 in, im assuming the dealer used some cheap dodgey oil, so im going to keep an eye on it now, would crap oil burn excessevly?
    Couldnt see any leaks around engine, and no spots on my driveway or garage floor.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    I hadnt noticed any when i got it, got my dad to follow me on the way back from the dealer and there wasnt any smoke, ill get someone to follow me today to see if there is any smoke with the new oil.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Even crap oil won't burn five litres in 5,000 k's!
    Barina with Chrome Plated grease nipples
    Jun 2011
    Up the Raod
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    2007 VE omega
    Feb 2011
    perth WA
    If it was burning that much oil...you would notice the smoke and it would run like a bitch.
    If there's no visible leaks, I'd be inclined to think it wasn't checked properly or filled up correctly.
    I know that sounds like I'm calling you a retard, but it just not possible for a modern low km engine to use that much oil without smoking or a leak.
  15. #15
    Feb 2009
    longford, victoria
    if its burning oil you should see smoke. especially 1 litre every 1000 ks.
    have you got under the car and checked for leaks?
    my geminis
  16. #16
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Thanks for the help guys,
    Im gunna jack it up tomorrow and have a look underneath for leaks, couldnt see anything from the engine bay at all..
    I hadnt noticed any smoke when driving, and its either on my driveway or in the garage and there is no oil leaks on the ground there.
    I checked it today (about 500km after putting in 4.75L of oil, didnt change filter or drain it cos I was at a servo) and its already really dark colour. The oil cap is dark/looks caked on with oil/burnt on, looking in the oil filling hole it looks like the cams are dark aswell (dunno what they are like normally on these cars).
    At this stage im just hoping it is somehow leaking as that would be better than burning it..
    Most of my driving is at 110+ km/h on highways, taking off quick at lights and using the gears down mountains to slow down, would this contribute to excessive oil consumption?
  17. #17
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Ahh sounds like you bought a sludger, engines farked.
    Report the sludged engine immediately while its under stat warranty and say u want a refund or a new/recon engine.
    Silver Certified.
  18. #18
    2007 VE omega
    Feb 2011
    perth WA
    Yep there it is...good condition engines don't turn oil black even after 10000kms. Sorry to say mate but it's time for a recon, id be straight back to the dealer.
  19. #19
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Was it even Engine oil they put in???
    As many have said take it back to the dearler and I'm afraid RiCeY could be right you bought a sludger.
    You could get an engine oil flush put through the engine a few time to see if it helps... otherwise an engine oil flush could make it worse and really show the engine is farked.
    Not good either way, sorry man.
  20. #20
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Problem with flush is it can dislodge chunks of sludge and block the oil pickup resulting in oil starvation and seized engine.
    That being said we've had a few badly sludged engines where they were willing to take the risk so filled them with clean oil in threw in a few bottles of engine flush and idled for an hour or so with no issue. Drained and refilled with clean oil and it did make an improvement.
    In your case you should still have stat warranty so Id be demanding a recon engine.
    Silver Certified.
  21. #21
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Quote Originally Posted by RiCeY View Post
    Ok thanks heaps, how much oil should the engine use if its running normally?
    It going to the dealer monday to be looked at.
  22. #22
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
  23. #23
    Jun 2011
    Gold Coast.
    Modern engines use zero oil if in good order.
    Is it all oily and greasy when you run your finger in the exhaust pipe? As said though using as much oil as you say you would have to have a pall of blue smoke behind you and the EPA chasing you. Sump on the outside should be perfectly clean and dry too.
  24. #24
    calais06's Avatar
    VE Calais MY06
    Jul 2011
    Sydney, NSW
    Quote Originally Posted by gossie View Post
    The tailpipes just have the usual black soot-like deposits, not oily or greasy though.
    Looked under the car today, looked like there was just a little oil, possibly from when i was filling the oil without a funnel and a bit missed lol. Not 5L worth of oil though, probs just a couple of spills on my behalf.
    Its under the stat warranty so hopefully it will get sorted
  25. #25
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    Ok, wow... you can believe what ever you want however what is the PCV system on our engines for then?
  1. VT Calais - Replaced DFI & Now When Turning Over Made A Bang & Burning Smell
    By bennoc in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-01-2010, 02:36 PM
  2. Huge Sale Vn Calais - Vs Parts Stato Parts Etc Etc Heaps Of Stuff
    By petezor in forum Parts And Other Items For Sale
    Last Post: 02-03-2008, 04:48 PM
  3. burning oil
    By vkhawkey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-08-2006, 09:22 AM
  4. HEAPS OF VN CALAIS STUFF, spoiler, elec switches, garnish + bootlid.
    By wizza in forum Parts And Other Items For Sale
    Last Post: 16-05-2006, 03:54 PM
