Its seems both my lights no matter how they are adjusted keep dropping (left is worse). When I use the adjuster to get them up to an acceptable hight,it feels like they have screwed themselves out (like screwing a bolt in backwards on a nut) just wondering am I able to
A.Pull apart and put these back together
B.Buy just the adjusters and replace them
C.Do I have to buy a complete light assembly
is your car still under warranty?? if so you could suss it out at holden and see if they can fix it for free, i doubt holden will sell just the adjusters.
check out my executive >>http://forums.justcommodores.com.au/...executive.html
No its out of the warranty period
did you know on bottom of the lights. where u bolt them is a adjuster to tilt the lights. you have to remove your front bumper. not hard to do. and you will see 4 bolts holding the lights in at the bottom is 2 bolts. when u remove them you will see a large nut. this is a adjuster to tilt the main light body. that can be adjusted to tilt the lights up or down.. give this ago.. i just replaced my standard lights with projectors and hid and am very happy with the look and lights. hope this helps.
http://iagresearch.com.au/index.php?...d=29&Itemid=40
