Results 1 to 23 of 23
Like Tree5Likes
  • 3 Post By nils7
  • 1 Post By gsh1970
  • 1 Post By Fekason
Thread: Easy OEM VE Front Dash 12V Socket Install (Alternative to Cigarette Lighter purchase)
    VE SS V Ute
    Oct 2009
    Default Easy OEM VE Front Dash 12V Socket Install (Alternative to Cigarette Lighter purchase)
    Hi guys, ever wanting a spare 12V socket for the VE Commodore in a place that Holden should have placed it - that is - under the audio unit, without having to buy a Holden Ashtray Cigaretter Lighter kit?
    I replaced my compartment space with a Pontiac G8 front 12V socket kit (see pic), its a tidy OEM install and is better than the Holden Ashtray kit as it provide the user with extra space to place items as well looks a cleaner install.
    The GM part number is 92206136 Compartment.
    Im sure you will be able to order from Holden or get one from a pontiac G8 wreck from the states.
    Its an easy install and requires removal of the trim surrounding the gear stick and undoing x2 screws to remove the exisiting blank compartment space, and replacing with the G8 12V socket kit. The G8 12V socket requires wiring up to the exisiting spare cigarette lighting wiring which is housed underneath the audio unit, this is accessed by removing the centre compartment driver side panel (see pic) and unclipping the cigarette lighting wiring clip. For some strange reason the clips on each do not mate correctly but to resolve this i just mated the two using spare wire and spade terminals. The spare cigarette lighter clip will have three terminals, pos, neg and lighting for the cigarette lighter ring, the thrid is redundant when using the pontiac 12V socket kit.
    As you can see in the pic its a clean install, takes bout 10 mins.
    Last edited by Troy711; 07-08-2011 at 06:45 PM. Reason: No advertising within the technical areas.
    SV6.07's Avatar
    SV6.07 is offline Enjoy it Drive a Holden
    2007 VE SV6 Nitrate & 2011 VE SV6 Poison Ivy
    Oct 2010
    Melbourne,Victoria
    love this idea. hate having to plug my power into the centre console. will see about getting one too.
    VE Omega - SS Mock Up
    Feb 2011
    this is definitely something i will be doing in the near future. Thanks for the info
    2010 VE SV6 Ute and 2010 VE SSV Sedan
    Nov 2009
    VE Omega
    Nov 2010
    That Looks real good defs gonna do it, but will also hack a usb port in to it.
    if any one finds a reseller pm me thanks
    Check out my VE Commodore My Omega Mods
    itsArthurKomar is offline sexy beast
    super awesome time machine
    Apr 2011
    ya asss
    try the wrekers. got a sv6 foglight switch from one and i have no use for it now lol
    Quote Originally Posted by BigBoss View Post
    N/A Yet
    Apr 2011
    Ballarat, Vic
    Apr 2011
    ya asss
    30 bucks can sell it to u if your interested
    Quote Originally Posted by bdc74 View Post
    what did that one cost you?
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    this is awesome.... but finding one of these is going to be really hard for local folk .
    thanks for write up and pics OP
    2007 VE omega
    Feb 2011
    perth WA
    Perhaps JHP should be informed of this and see if he can get some import happening?
    UFO's Avatar
    UFO
    Oct 2009
    VE Commodore SSV
    Feb 2010
    Looks good, I'm going to be on the look out for one now. If anyone finds them can you please PM me too.
    N/A Yet
    Apr 2011
    Ballarat, Vic
    VE SS V Ute
    Oct 2009
    i bought mine off ebay, look under pontiac G8 wrecks, here are photos of the part numbers for the units. they look like they are made from GM here in australia as i believe the pontiac g8s were exported to the USA? try ordering the part number through a dealer.
  15. #15
    VE SS V Ute
    Oct 2009
    here are some install instructions for the orginal holden cigarette lighter accessory, most of it applies to fitting the G8 12V front socket, sorry the quality is not good, but founnd these off the net and they were useful for my install
  16. #16
    2010 VE SSV ute XYZ XYZ
    Jun 2011
    I just did this today with help from the original poster (cheers mate) - works great. Couple of tips: I removed the plug from the 12v part and crimped on blade connectors and then clipped them on to the cigarette accessory plug that is standard in the VE. Was 3 terminals - on that plug: bottom is positive and I used the top left for the negative as the top right worked but caused interference to the picture from my reversing camera on the screen if the new 12v was used with eg phone charger. Now it is installed 12v socket only works when ignition on but also stays on when key removed for about 20 secs - same time as headlights stay on if u choose egress lighting in your set up options / I'm not a mechanic, I'm a lawyer and I had no problems doing this - took me about an hour as I had to research how to take centre Console out / I worked through the gap where this new part fits - I didn't remove the side trim line the original poster for fear of breaking clips etc when removing so was a bit fiddly but all good
  17. #17
    VE Omega
    Nov 2010
  18. #18
    2007 VE SV6
    Jun 2011
  19. #19
    VE Omega
    Nov 2010
    Thanks for that link , but OMG i think that is quite pricy.
  20. #20
    Jun 2011
    That's the wrong part: don't get the smokers kit: scroll up to original post - get the 12v accessory part
  21. #21
    Fekason is offline Fekason
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    Default Prices
    I bought the front and rear smokers pack from the local Holden dealer a year and a half ago. Cost was $104, so the Ebay price seems steep.
    I was pleased to find that the Series 1 kit fitted straight into my Series 2 when I upgraded.
  22. #22
    06 VE SV6
    Aug 2011
    Hi Guys. Just hashing up my own 12v/USB port to hook up to the front plug. Can someone tell me which colored wires to use? I am assuming the black one is ground, but should I use the white or the brown/yellow wire for 12v? (I don't have a volt-meter to figure it out). Cheers.
  23. #23
    VE SV6 Sportswagon
    Oct 2011
    Liverpool, NSW
    I would like to get one of these having problems, can any tell me where it can be purchased from ? Thanks
  1. VZ No power to cigarette lighter socket
    By davevz in forum Electrical Wiring / Questions
    Last Post: Yesterday, 03:09 PM
  2. Cigarette Lighter/Accesories Socket
    By 2005vzute in forum General
    Last Post: 19-07-2010, 11:55 PM
  3. Waterproof Cigarette Lighter Socket ??
    By woteva in forum Electrical Wiring / Questions
    Last Post: 21-10-2008, 11:04 PM
  4. VY Cigarette Lighter Socket
    By pedrod59 in forum Electrical Wiring / Questions
    Last Post: 17-07-2008, 05:15 PM
  5. cigarette lighter socket
    By VYMAD in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-06-2008, 11:39 AM
