Results 1 to 14 of 14
Like Tree3Likes
  • 1 Post By Tommo_27
  • 1 Post By shane_3800
  • 1 Post By RUF-60L
Thread: Installing swaybars
    RUF-60L's Avatar
    RUF-60L is offline Donating Member
    2008 VE SS
    Nov 2010
    Default Installing swaybars
    Is this an easy DIY job on a VE???
    Quote Originally Posted by dingdong555 View Post
    Be careful not to hit yourself in the head whilst pulling
    My Ride, RUF60L
    VE SV6
    Apr 2009
    I think the rear will be. Just have to unbolt your rear mufflers to get the bar out. Havn't had to good a look. I plan to do it myself when i get around to it.
    I had the front done for me. You have to drop the K frame. Don't know how hard it is but i couldnt be bother so got pedders to do it for me.
    vr commo
    Aug 2011
    places
    RUF-60L's Avatar
    2008 VE SS
    Nov 2010
    Yeah we got the rear in just unbolted the exhaust to drop it enough to the bar out/in. Front looks difficult so we didn't try it
    My Ride, RUF60L
    2010 VE SV6 Ute and 2010 VE SSV Sedan
    Nov 2009
    I never had to unbolt the exhaust to change my rear sway bar...
    Quote Originally Posted by RUF-60L View Post
    RUF-60L's Avatar
    2008 VE SS
    Nov 2010
    3" pipe kinda gets in the way
    My Ride, RUF60L
    2007 VE SS
    Nov 2006
    will changing the sway bar reduce the f#cking axle tramp like donkey kick burnout rejecting shit that happens when im tryina get sideways? if so, what sizes have people gone etc? (im not very mechanical.. ha)
    TinSnips's Avatar
    TinSnips is online now Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    nope. You need the replacement sub-frame bushes that fill the void to help with that - higher-damping shocks will help also. Sway bars keep the body roll through corners in check and keep the weight more evenly distributed.
    VE SSV 60th Ann
    Oct 2010
    A mate works for Pedders. Very hard and time consuming (ie lots of labour costs) to do front. rear is very easy as I understand it
    As for the above post, Diff bush will help also and Pedders also now stock a gearleaver bush that tightens up that whole area
    Bonners White E3 Clubsport - SV Enhanced
    Wortec Brakes Distributor
    2007 VE SS
    Nov 2006
    tin and bonners. expensive to do this ? its lowerd on kings with monroe gt sports and that helped a bit but i want it stiffer!!
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    VE SSV 60th Ann
    Oct 2010
    Quote Originally Posted by -vkhg View Post
    I'll get a quote for you so you know.
    The other bush has something to do with that 'cradle' the gear lever bolts to. I'll get a pic of it. It is very easy to fit apparently.
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    2007 VE SS
    Nov 2006
    Quote Originally Posted by greenacc View Post
    uh whats a Gearleaver bush ?
    -vkhg, try Viagra.
    no good, gives me two gear levers but thats it..
    Quote Originally Posted by bonners View Post
    cheers mate!!
  1. VS Swaybars and exhaust fit Vx??
    By despo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-12-2010, 05:10 PM
  2. swaybars for utes
    By Ross D. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2009, 05:27 PM
  3. swaybars
    By ashzv6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2009, 12:24 AM
  4. swaybars
    By skyper in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2008, 05:41 PM
  5. Upgrading swaybars in VT
    By SS202 in forum General Discussion
    Last Post: 19-12-2006, 02:41 PM
