So 30 minutes ago I've come downstairs to head to work, pressed unlock on my key, nothing, pressed it again, nothing, pressed it 5 or 6 times still nothing.
Thinking I've got a flat battery in my remote I used the key to open the door, key in the ignition, no power to anything.
Rewind to Thursday I went in for my 1st service, which was 4 hours. Not until I'm almost on the M5 on the way back home do I notice that I have no sat nav. Called them, they said it would take 2 hours to fix.
Took it back to them on the Saturday, after 3.5 hours I'm told my IQ unit was blown and they would have to order a replacement.
And now I'm sitting here late for work waiting for roadside assist to turn up. NOT HAPPY HOLDEN!!!
I am here: http://maps.google.com/maps?ll=-33.896480,151.161520
that sucks mate....at least its under warranty
My sv6 did that, series 1 so doesn't have IQ but I got the battery checked they said it was fine, took it to Holden for a software update and they said there's no current draw. They said it was the battery.
It went flat after I didn't drive it for 2 full days then I left it for like 6 days two weeks later and it started fine. Silly![]()
Same thing happen to me. About a month ago. Series 1 09 SV6. EXACT PROBLEM. Funny thing was i had a spare battary in the shed so i thought i would change it but you cant open the boot with a blown battary and the battary in the boot
After waiting for road side assist for 4 hours, i rang them again 2 hours later again then i got angry called my dad, my dad called LEXUS(mums car) roadside assist. FUNNY THING IS IT WAS RACQ aswell and they came in 20 minutes and my dad got them to do it.
It really is patheic
Just thinking out allowed but is there anyway you could get in to the engine bay? (maybe from underneath?) If so you could slap a battery charger on to that red plastic covered positive terminal. that would give you enough charge to pop the boot and then properly charge your battery or switch it out for a new one.....
Check out my VE Commodore My Omega Mods
If you can get in the car, there is a yellow tab near the centre rear set that allows you to open the boot without power to check battery.
No it won't.
The key only operates the central locking system which does not work if there is no battery power. It is not a mechanical key.
The RACQ had to prize open the door frame a little at the top to insert a long wire to pull the bonnet release !!!!
RACQ roadside assist is a joke
note when you do that all the doors unlock (central locking) not just the driver's door
try lifting the bonnet, lock the doors, disconnect the battery and try the key - see how you go
even if the battery is flat or disconnected you can still open the car by manually by the key it takes a bit of effort but still does & why do i open my bonnet the battery is in the back
The Mad Dutchman
you can unlock the car manually, once in you can open the bonnet (which is mechanical) you can jump start it by using the two terminals or even get into the boot to change or charge the battery by pulling the yellow ring that you can see if you pull down the middle seat(which is also mechanical)
I know this cause I left my lights on accidentally when changing them which completely drained that battery.
Sorry I meant open the the boot, I said bonnet as that had to be opened to connect another battery to open and start.
Have you ACTUALLY used the key when battery has been disconnected or dead flat?
yes i have, when i had the battery out of the car and the missus shut the boot! put key in and turn. Holden would not make a car that you cant get into if the battery was dead!
Exactly.... and its not just Holden, it's anyone. There's a reason keys still exist, and there's a reason bonnet releases are still mechanical and not electronic. Safety first and foremost... regardless of power (or lack there of due to fault or battery drain), access to cabin and engine bay must always be available. I'm not going to waste hours reading up ADR's now, but without question there would be a requirement for mechanical release to doors and bonnet that doesnt rely on power.
