Results 1 to 5 of 5
Thread: VE Battery Ventilation Tube
    VE Omega
    Aug 2011
    Auckland, NZ
    Default VE Battery Ventilation Tube
    Hi,
    I recently bought a second hand 2007 VE Omega, and have had some battery issues. I've bought a new battery for it, but when I went to fit it following an online guide, I realised the old battery didn't have a ventilation tube attached.
    I've gotten a replacement one of those too, but I can't figure out where on the inside of the battery compartment the other end of the tube is supposed to be fitted for external ventilation.
    Does anyone know where it goes, or if it is safe to just route the tube between the back of the battery and the inside of the guard?
    Thanks,
    Zylon
    VE SV6 ute
    Apr 2009
    vic
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    no ventilation tube on mine.... battery should be a sealed unit because of its location in the cabin.
    VE Calais v 6.0
    Oct 2010
    victoria
    Not sure if you got dual mufflers but,looking from under the car, the hole is located where the lhs muffler is, just above it to the left. You should see a rubber, feed it through there.
    vx
    Aug 2011
    sa
    Quote Originally Posted by UFO View Post
    yes the battery is a semi sealed unit, the top caps dont have vent holes, but in the top is a moulded in vent passage to hook up the gmh vent tube,,, holdens used a white case battery for the usa market ,made in italy charged here in adelaide,, all OE battery are exide,,, battery specs if you can find theese batteries out there they are what we sell to the aftermarket ,but are the same as gmh but with diffrent labels
    LN2==55h exide
    LN3==66h
    LN4==77 h current cruze deisals use a LN4 but diffrent labels again
  1. Air-con/Ventilation woes
    By c2105026 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-07-2011, 11:20 PM
  2. how much ventilation does a computer need?
    By gopher in forum The LAN Lounge
    Last Post: 20-07-2009, 09:18 PM
  3. Ventilation Valve
    By colincritter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2009, 01:36 PM
  4. Ventilation Problem
    Last Post: 31-03-2009, 06:49 PM
  5. Battery in boot - ventilation requirements
    By DANNY8 in forum Electrical Wiring / Questions
    Last Post: 24-09-2007, 11:45 PM
