Results 1 to 5 of 5
Thread: problem
    ve ss
    Feb 2010
    Gold Coast
    Default problem
    Yesterday I was driving along in a bit of delayed traffic and the temperature gauge started heading to hot I notice this because the fans kicked in so pulled out of the traffic to have a look to see what's going on under the bonnet thought might have done hose but all good only just got to half and then calm back down. So my thought maybe the thermostat stuck. But to day when the other half was driving it this afternoon from robin to southport the temperature gauge didn't even move off cold but the car was operating normal. She turned the car off and restarted it the temperature gauge moved to normal operating temp on the gauge. When she got to southport.
    Has anyone else had this problem?
    Car is booked in on Monday to see what's going on.
    Car is ve ss 2006 coming up to nearly 100k on the clock
    VE S2 SV6/A6
    Apr 2011
    Do you know what temperature it got to?
    I've seen mine hit 108c only in the M5 east tunnel (Sydney) in stopped traffic,- ambient temperature outside at 30c, but expecting more when it gets closer to summer.
    Current Ride: 2011 VE Sedan - In Voodoo of course.
    Last Ride: 2004 Subaru Liberty GT, Twin scroll turbo, tuned, Bilsteins, sway bars, no rice, 420Nm
    Also Own: 1964 EH Wagon, modified interior, minor modifications outside
    VE Omega 08 MY09
    Nov 2010
    Gorokan NSW
    Under the circumstances it sounds perfectly normal to me.
    Traffic not moving much, bugger all air flow, temp rises, fans cut in (as they should), if the temp dropped after a short while then no probs. If it didn't drop then you have a problem.
    ve ss
    Feb 2010
    Gold Coast
    Quote Originally Posted by Bill44 View Post
    This is true but temp was increasing fast and it wasn't even hot at the gold coast that day and today with temp gauge not to even move at all. Like not even move to normal operation temp .
    2012 S2 SV6 Sedan
    Apr 2010
    Sounds like a fault in the coolent temp sensor or software glitch.
    The temp gauge in earlier model VE's use to fluctuate between the quater needle mark and nearly half way dependant on the movement of the car (either sitting in slow moving traffic or waiting at the lights to sitting on a constants speed above 60kph). There is a dash/cluster software update (in 2010) which now has temp gauge to read just over the quater mark (so slightly higher than it use to).
    Now the temp needle doesn't move no matter what driving conditions your in. If yours is going from not reading an engine coolent temp to halfway and above I'd say there is potentially an issue with the coolent temp sensor. While your at holden get them to SPS the dash/instrument cluster for a software update. The new reading will ease your mind..
    If you have to replace the sensor: Holden Part No. 12608814 and costs around $40 +/-.
    Phil
    If your not living life on the edge, then your taking up space!
  1. vs statesman problem, possible emobiliser problem?
    By Mbro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2012, 10:28 PM
  2. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  3. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  4. Central locking Sv6 problem. this going to be a problem car??
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 10:40 AM
  5. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
