Hey all,
What do you think of the "high flow" air intakes?
Holden Commodore VE K&N High Flow Air Filter V6 V8 HSV | eBay
Check out my VE Commodore My Omega Mods
Definitely makes it breathe easier .
nathans VY Calais - 'Calais 2.0' | VT Equipe | VS Calais **SOLD!**
That's all I have in mine at the moment - but if I'm honest, the only benefit I've found is that I don't have to go out and buy filters now.
Why not for $69.
I got 1 too easier breathing and never UAE to buy another filter again
07 VE SV6
Mods: K&N high flow air filter in box, x-force 2.25" cat back system
Sound System: Alpine type r fronts and rears, 2x Alpine type r 12" sub, Boss audio 1500 watt mono Amp, Kicker 450.1 Amp
Do you have to oil these? Or are they a dry filter?
Wouldn't mind getting one but don't like the idea of oiling an air filter. I think it would foul the MAF meter over time.
VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
K&N is oiled.
Thanks for the reply guys.
Normally i'm very good at feeling things through the car, and when I had my VZ alloytec and dropped in a K&N panel filter, nothing changed. As mentioned, it's only good in the long-run as to avoid purchasing paper ones. But considering its $67 and a paper one is $15, you will only break even after you would have replaced the filter after 4.5times.
When you re-oil the filter, just grab a can of MAF cleaner (SCA and the like have it) and clean the MAF while you're there
I went with BMC but like others have said I also didn't get much difference. saying that this is one of the easier and better things that should be done to every car. BMC is also oiled but as long as you read and follow the instructions carefully you shouldn't have any problems with your MAF
Lukey aftermarket filters are non-oiled...
and blue.
no idea what their flow is like though.
I heard the K&N VE filters are shit and let alot of shit through that could damage the engine... is that correct or just B/S ?
I had a vt with a k&n filter and it ruined the maf.
Never again IMO
No Replacement for Displacement
I used k&n on my old vs for 3 and half years no problems, my otr also has a oiled k&n filter and when i had a maf no problems either, so if u clean and re oil correctly you will have no trouble simple as that
ah ok cool thnx for clarifying![]()
Just found this!!!!
K&N OE Stock Replacement Air Filter Pontiac G8 08-09 | eBay
Get on it people![]()
That one works out to almost 100 bucks with shipping mate.....
