Results 1 to 7 of 7
Thread: Ve coolant question!!
    VX acclaim S2
    Oct 2009
    Default Ve coolant question!!
    So I noticed I was leaking coolant, pressure tested it, and found my heater hoses to be leaking, will need about a liter of coolant I'm told, just wondering if I can mix the factory stuff with Red nulon long life???? Of course after i replace them, any tipS would also help?
    VE SV6 Sedan
    Jun 2011
    brisbane
    Good question I will need to kno this as my water pump bearing is giving up. Makes a lovely scratching sound when she is cold
    07 VE SV6
    Mods: K&N high flow air filter in box, x-force 2.25" cat back system
    Sound System: Alpine type r fronts and rears, 2x Alpine type r 12" sub, Boss audio 1500 watt mono Amp, Kicker 450.1 Amp
    VE Omega
    Aug 2009
    Toowoomba, QLD
    How many KM and has the coolant been changed before? If it's a couple of years old it wouldn't hurt to drain and flush then refill with the new stuff with quality water. Also keep in mind when topping up or refilling that you can sometimes get air locks so keep a good eye on the temp gauge and top up again if required
    Oh and to answer the question, I wouldn't recommend mixing coolants of either different brand or adding new coolant to an old mix.
    Commodore
    Jun 2004
    NSW
    get rid of it all mate and get genuine stuff or nulon....one or the other
    Do not mix them !!
    U learnt this a hard way in the past
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    What does holden use in these ? mine needs new coolant as well, i don't believe the 5 year unlimitted K's claim.
    MY07 VE SV6 M6
    Aug 2011
    Holden uses acdelco red extra long life coolant for all engines cast from alloy, that is supposed to last 5yrs, however at work we recommend it to be changed every 2yrs. With the v6s, they can be a real pain in the neck to bleed air from the system, sometimes we have to elevate the front of the car to help the air escape out of the filler neck as most air locks occur in the heater core.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    As said dont mix coolants.
    Also theres a bleed screw on the top of the radiator, drivers side. Leave this open till coolant flows out then close it then run for a while (till it reaches running temp) and remove again till coolant flows out. You really need a radiator hose jammed in the fill point to raise the high point of the coolant when youre bleeding the system. When the fluid starts to whirlpool at the fill point its bled and flowing correctly.
    Silver Certified.
  1. Another coolant question
    By avanti_rider in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-06-2010, 05:49 PM
  2. Coolant question
    By quombone in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2009, 02:09 AM
  3. VP coolant question
    By spoonfork in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-11-2008, 12:27 AM
  4. coolant question
    By fishman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2007, 11:56 AM
  5. coolant question...
    By Lish in forum General
    Last Post: 04-01-2006, 11:22 AM
