So the approach lighting feature is quite a nice inclusion, to show off the lights at night when you unlock the car makes it look much better
but how do you get the fog lights to turn on aswell? i have the switch on but they wont turn on with the approach lighting, any ideas?
It's probably just designed for the headlights lights to come on and nothing else. Not sure if that could be changed.
I'm pretty sure the foglights will only switch on with the ignition. Unless you live in an area which is foggy 24/7 you would have to be a muppet to leave your foglights on anyway.
And drain your battery twice as quick
Current Ride: 2011 VE Sedan - In Voodoo of course.
Last Ride: 2004 Subaru Liberty GT, Twin scroll turbo, tuned, Bilsteins, sway bars, no rice, 420Nm
Also Own: 1964 EH Wagon, modified interior, minor modifications outside
Read this thinking someone else had a idiot install reverse sensors without a relay...
So when approach lighting comes on, if you walk near the sensors the beeping would go off....
Yeah, it would not be easy to do electrically, as you would need to determine if the ignition was off, when the headlamps were on.
(Basically ignore the Fog lamps switch), as you would not want to leave the fog lamps on 24/7 just so the car would look good at night time when you unlock your car.
If you like the lights on approach / egress feature, how about fitting mirrors from a calais/statesman/caprice with the puddle lamps ?
Or even fitting the door lamps if they are not already fitted.
The puddle lamps make the car look that much more classy at night time, and do not chew anywhere near as much power as the fog lamps would.
Just my 2c
It is not possible for the fog lights come on WITHOUT the ignition
They can be used as a daytime running lights with the lights switched to parkers and the switch pulled out
They can be use the normal fogs with the switch set to auto with the switch pulled out, In both cases, you need to have the ignition ON
Re puddle lights, they are 42mm 10watt festoon bulbs, same as the under door courtesy lights, boot light, glove box light and footwell lights
I have fitted H11 35 watt HID (true plug and play bulbs) to my WM fog lights and they look amazing eBay Australia: Buy new & used fashion, electronics & home d
I have also fitted T10 LED's to my parkers, they are 9 X 5050 SMD and they ARE pure white, not bluish white eBay Australia: Buy new & used fashion, electronics & home d
All of the other 42mm festoons have been replaced with 6 X 5050 SMD flat festoons eBay Australia: Buy new & used fashion, electronics & home d Maybe not quite as bright as the standard 10 Watt festoons BUT they are pure white
I think that's cause the reverse sensors are wired through the reverse lights and the come on with the approach lights
I did notice that with my VY, approach lighting always used to turn the fog lights on (if they were left on), and even high beams if they were left on. When I got my VE, I found that this no longer happens. It's the same with the delay lighting - the VY's lights and fog lights used to stay on when I was walking away from the car, the VE's fog lights turn off as soon as you switch the key off. All thats left for approach/delay lighting is your standard headlights, regardless if the fog lights are set on. These will only turn on once the key is turned to ignition.
Ben
