Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By nashssv
Thread: In Car Computer - SSV
    VE SSV Ute '08
    Aug 2011
    Mandurah, WA
    Wink In Car Computer - SSV
    Just got an '08 SSV Ute 6 Spd Manual looking at installing an in car computer into the head unit. Should only cost around $1,500 AUD.
    Will Need
    RCA AUX plugs, goes into the AUX ports behind the stock SSV head unit.
    PORARES Car PC Intel Core i5 3.2G CPU 4G RAM (Up to 8G) 160 HDD.
    HDMI to Yellow/White/Red RCA Connector to go from the PC to the AUX plugs.
    7" Touch Screen Overlay kit is placed over the factory LCD Screen ran into the computer via USB port from Cyclotouch.
    VIM Kit (hoping to find a place in WA that can do it, any known of much appreciated).
    From what I gather that is all you need so that once the AUX button is pressed on the head unit it should switch to the "Carputer".
    With that you should be able to play music, movies, use GPS software (with USB GPS antenna), go on the net (with Wireless Broadband Modem), pretty
    much anything you can do on a computer.
    HiTV Communications Integrated in car entertainment solution, digital TV GPS DVD headrest have done something similar with a navigation unit so i'm assuming it can't be too hard :P. Will keep yas posted. Any knowledge on this
    would be sweet as.
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    ive got one in my computer came with the car, will sell for 800 if keen, comes on with aux has nav which cuts music when saying driving instructions regardless of icc state, music?video player, usb and sd card input no HD but fits nicly in glove box and has wirless touchpad (like computer but smaller) all in all its preety cool but i want to get rid of it to run a proper processor
    Astranomical's Avatar
    Astranomical is offline Ecotec just kicked in yo
    Hammerhead Eagle i-Thrust
    Apr 2004
    Dee Why, NSW
    Quote Originally Posted by nashssv View Post
    I'd be interested to know how you go about getting analog composite video and analog audio out of HDMI - it is a digital interface, and does not carry any analog data at all. The only way I could imagine you'd be able to get analog out of it would be with some kind of converter box. While you will be able to connect the PC's speaker output to the head unit's AUX input, you'll need to find another way to get video from the PC to the head unit. If your PC has a PCI slot you could probably install an older PCI video card that has Composite RCA out (which you can just connect straight to the HU) or S-Video out (which can be converted to Composite with a $5 adapter)
    Quote Originally Posted by som
    i saw a camira a while ago that wasn't blowing smoke.it was on the back of a tow truck.
    Ve SSV sports wagon series 2
    Jul 2011
    If you look on eBay you can buy a lead that will convert digital to analog it goes from HDMI to component or you can get RCA the signal will only work one way HDMI out RCA in I got one for my Old TV so I could connect my new DVD player to it which only had HDMI out put or RCA no Component.
    VE SSV Ute '08
    Aug 2011
    Mandurah, WA
    Ok bit of an update since i haven't been on in a while. Had the car for just over two weeks now. Got the 22's on it, flat slimline hard top on the way, suspension put on to give it a nice "low look" with the 22's but to keep it practical for WA driving -.- , I have just about finished with the in car computer and will post a video on youtube once i get the touchscreen overlay installed. I did have the problem with the HDMI to Composite cabling but ended up with a VGA to composite converter since I bought a cheapy netbook to run the system off (bit strapped for cash at the moment as working away was canned so my income in less expendable :P) but would be simple enough to upgrade to a better system later.
    In Car PC
    Samsung 10" Netbook 250GB HDD Space (don't need a lot as everything is run off an iPod)
    Centrafuse Auto CarPC Software with Nav Function (Centrafuse™ | Connected Car Applications)
    VGA to RCA Converter (DickSmith)
    Rear Auxilary Cabling (From JHP)
    VIM Kit (Alberts Morley)
    Touch Screen Overlay (Ordered from HiTV through Alberts Morley)
    SiRF III USB GPS Receiver (Westec Electronics Perth)
    Laptop DC Charger for Cars (Westec Electronics Perth), Connected to a Cig Lighter installed by Alberts with a supressor to counter annoying whine from Grounding Loop Problem (Pain in the ass to resolve)
    All the Generic RCA Cabling aswell as USB Hub for Glovebox and USB Extension Lead to run from behind passenger chair to glovebox.
    To work out the cost you can do your own math, basically works out cheaper than the Holden Nav System and you can do so much more with the system. Will post a video when I get the touchscreen installed and will put pictures up shortly.
    VE SSV Ute '08
    Aug 2011
    Mandurah, WA
    In Car Computer - SSV-ute1.jpgIn Car Computer - SSV-ute2.jpgIn Car Computer - SSV-ute3.jpg
    Before and After, Looks a bit lower now suspension settled a bit more. Also have the windows tinted. 5% on the back and Quarter Panes and 35% on actual window. Kept it legal.
    VE Omega
    Nov 2010
    I am interested to see how your carputer compares to mine.....
    Check out my VE Commodore My Omega Mods
    VE SSV Ute '08
    Aug 2011
    Mandurah, WA
    Yeah I had a quick look at yours and looks great pretty much similar idea. i'll upload a video now give me an hour and i'll have it up. only difference would be since i'm using the ssv stereo i'm able to keep the stock ssv looking dash. pros and cons to it though as with anything
    VE Omega
    Nov 2010
    VE SSV Ute '08
    Aug 2011
    Mandurah, WA
    Sorry recorded it with my phone and it came out at like 1.5GB cause i did it in full HD ><. Will do one up tonight with pictures etc. going to attempt to install the Overlay by myself cause CBF waiting for monday -.-
    VE Calais V 6.0L
    Aug 2011
    Sorry for silly question.
    Is there any reason why you are not using the VGA video input on the screen (Sat Nav Input) instead of the Aux Video Input ?)
    It may make things a lot easier for you.
    Does this input need to be enabled (TECH2) or do you need the Nav Facia for this to work ?
    I have the factory Sat Nav, and the back of the Sat Nav unit has an old School VGA connector.
    I have never been able to get the connector off and try to connect it to the laptop to see what resolutions it supports, as it has been screwed in extremely tightly, and it is difficult to get a flat bladed screwdriver in there.
    I have been looking at doing something very similar myself, though I havent really put too much thought or time in to what is required
    VE SSV Ute '08
    Aug 2011
    Mandurah, WA
    Mate that could be something for me to look into would make things so much easier. I had no idea the Nav was connected with a VGA cable -.- there must be an adapter holden installs when they install the nav or something because i haven't seen any VGA cables hanging from the back of my stereo :P. The Quality is pretty terrible using the AUX input RCA cable so would make things a lot better. I'm uploading the video to youtube now. If anyone has any info on the VGA input for the Nav button would be much appreciated.
    VE SSV Ute '08
    Aug 2011
    Mandurah, WA
    VE SSV 60th Ann
    Oct 2010
  15. #15
    VE SSV Ute '08
    Aug 2011
    Mandurah, WA
    the aircon works like normal if you've got anything plugged into the AUX vid in it just brings up whatever you push on top of the display. All the carputer does is allow you to watch videos, operate GPS nav shit, pretty much do anything you can on a computer. The only problem I had when i installed the overlay was i hadn't put two tiny things back properly which made the menu button stick and the "fan up" button was missing the little plastic bit which attaches to the button to the chip. But pulled it apart and fixed that and then ####ed more shit so -.- FML just gonna take it to local auto sparky and he should be able to fix it otherwise i'll just get a new faceplate and start again ><.
  16. #16
    VE Calais V 6.0L
    Aug 2011
    I will have a look at the workshop manual for what is exactly connected for the Sat Nav.
    You are right, there is a connector that is added when Sat Nav is specified.
    The VGA Inputs are on the same connector s the Composite Video In.
    Pin 1 is for Blue,
    Pin 3 is for Red
    Pin 11 is for Green
    Pin 10 is for RGB Common
    Pin 13 is for CSYNC
    For reference
    Pin 14 is for CVBS1 (Composite Video 1)
    Pin 15 is for CVBS2 (Composite Video 2)
    I will have a look tonight to see what else is needed / used for Sat Nav.
    (I know the facia for Sat Nav is different, and it has a Sat Nav button where the Power button is, but I am not sure how to select/enable the VGA Input at this stage).
  1. is the trip computer the same thing as the computer on the passenger side kick panel
    By comfortss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2011, 08:07 AM
  2. Resetting your computer and trip computer special functions (VT - VX)
    By Darren in forum Holden Commodore How-To's
    Last Post: 19-01-2011, 07:05 PM
  3. [QLD] Wanted : VL turbo auto computer / trans computer
    By Goon in forum Swap / Wanted to Buy / Trade
    Last Post: 03-03-2009, 07:55 AM
  4. vk efi computer is the computer just for motor
    By quick202 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-04-2007, 11:13 PM
  5. trip computer/total distance computer STOPPED!
    By Juzzy21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 10:10 PM
