Results 1 to 6 of 6
Thread: Engine won't start when warm.
    VE SS 6 litre V8 ute
    Aug 2011
    Burpengary
    Thumbs down Engine won't start when warm.
    If ignition is swiched off when car is at normal operating teperature 95C, it will start again OK.( over and over) However leave it for 10 minutes and it will not start. Spark plugs are firing, but plugs are dry,fuel injectors are not opening to let fuel in. It stays like this 'till it's cooled down toapprox 38C after about 45 minutes.Cranking voltage 11 volts, running 13.5 volts. It's held me up quite a few times and is a pain in the A---. How do i fix it? L98 engine. Has anyone experienced this problem?
    vl
    Apr 2011
    brisbane
    could be a lot of things, if your in brisbane i could scan your car with a scantool
    Jan 2008
    NSW
    Ve SS
    Nov 2009
    i had the same issue with my vx,ended putting up with it in the end as it was becoming to costly to try and solve.
    Holden and others could not pinpoint the issue i had changed the battery,spark plugs,plug leads and got new key problem still there
    Holden adv that next thing would be to change fuel pump,relays or could be possibe issue with imobilser,but did not want to go that far but these parts cost to much and worked fine when started cold or it cooled down a bit
    Jan 2008
    NSW
    Quote Originally Posted by Hsv is king View Post
    That would most likely have been the crank angle sensor.
    Ve SS
    Nov 2009
    ok thanks,glad i stoped replacing bits
  1. VY Won'r start while warm?
    By stealthVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-01-2012, 04:22 PM
  2. Issue: Won't start when warm.
    By lukefraser in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2008, 02:34 PM
  3. warm start trouble
    By reardo_202 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2007, 02:14 PM
  4. VR stuggles to start when warm??
    By Famine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2006, 11:01 AM
  5. VT does not start when warm
    By RichardW in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2006, 10:00 PM
