Results 1 to 7 of 7
Thread: ssv ve ute
    ve ssv ute 6speed
    Aug 2011
    kingaroy qld
    Default ssv ve ute
    Hi all,
    I am having problems with my 2010 ve ss ute, it is breaking down at 3,500 rpm in every gear, i took it to the Holden dealer for inspection, they placed the tech 2 on it , nothing showed up ,no engine lights on and the mechanic told me that i had some water in the fuel.
    I guess this is possible, and i buy my premium fuel from the same servo each week.
    The ute has only done 13,000kms, k & n air filter and sports rear mufflers.
    Has anyone had this problem, the ute idles well and cruises well ,but when you want rapid acceleration it breaks at the above rpm.
    The holden dealer suggested that i use all the remaining fuel,refuel with some e10 and injector cleaner, if this fails the tank will have to come out and be drained.
    NIXONLS1 is offline Banned
    my mum
    May 2009
    Bansville
    ve ssv ute 6speed
    Aug 2011
    kingaroy qld
    Redline SSV
    Jun 2008
    Sounds like you have bad fuel mate. Is the ute ever jerky or rough when reving up to 3500? When it hits 3500 does it just get stuck there? Bad fuel killed my fuel pump which did this to my car a while back$
    ve ssv ute 6speed
    Aug 2011
    kingaroy qld
    it revs to 3,500rpm rapidly, no jerks or roughness until 3,500rpm then it won't rev anymore then that and breaksdown, then change gears,take off again until up to 3500rpm again and the same problem reoccurs.
    ve ss
    Feb 2010
    Gold Coast
    Not sure but when u stand still can u rev it past 3500 rpm also could it be the rev limiter set wrong maybe get them re install the software
    Also is the air intake wet and really oily this would make it do it to. Just a thought. Good luck to ya
    Redline SSV
    Jun 2008
    Get your fuel filter checked. It could be blocked from bad fuel if that's the problem.
