Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Not_An_Abba_Fan
Thread: Increased Fuel Comsumption SInce installing standard mufflers back on
    2011 SV6 Sedan
    Aug 2011
    Gold Coast
    Default Increased Fuel Comsumption SInce installing standard mufflers back on
    Don't know if you might of read my post a few days...long story short, guy ran up back of my NEW sv6, no real damage rear muffler a tiny bit bent at tip, took to exhaust shop and guy took me for a absolute ride - hind sight would of been grate!!!! and gave me straight through pipes which are way to loud especially since my wife gave me the news of a child on the way so quieter the better at this stage. So i fixed up standard muffler and put them back on....mmmm quietness Since doing that my fuel eco has gone up into the 11lt avg doing same driving route as usual when it was sitting on the 10lt mark, so for no real reason it has gone up???
    Is this because of the ECU relearning things?? or is it a exhaust leak from mufflers?? the bolts are tight trust me
    I know it may not seem like much but when you have constantly sat on 10lt for who knows how long doing same trip day in day out over 3500kms and get in car after changing mufflers and jumps to 11lt and over for no reason you start to wonder??
    VE ATOMIC SV6
    May 2011
    Well it does seem right, as when your purchasing an exhaust it usualy says that u get better throttle response, more power and IMPROVED FUEL ECONOMEY. I wouldnt have any clue to as why? but maybe somthing to do with less ristriction, MORE FLOW?
    Coz at the end of the day thats basically what an exhaust does, gives more flow?
    So i wouldnt say theres anything wrong with the mufflers u put on or whatever, seams perfectly normal
    Im no expert so if im wrong please correct me someone.
    BTW your sv6 is the SIDI yes? i thought it should do 10L ?
    2011 SV6 Sedan
    Aug 2011
    Gold Coast
    Yes it is the SIDI...I should clarify yes since new and before installing the straight through pipes i was getting 10lt avg, with them on slightly better at 9.7ltavg but since putting originals back on bang straight up to 11lt avg for no reason????
    VE ATOMIC SV6
    May 2011
    Im not sure then buddy sorry! but i would guess that because the exhaust had better flowing and now going to ristriction maybe it isnt use to it, give it a day or 2? But yeah no idea man sorry
    f6
    Feb 2011
    Mate try taking the battery off for a few minutes and reset the ecu and then give it a couple of days for it to re adjust and it should come back down again. Also have you checked the air filter
    2011 SV6 Sedan
    Aug 2011
    Gold Coast
    yeah it a 2500km old K&N air filter so all good there. I might wait till i fill up again and see if it has adjusted itself?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Did the muffler change and the filter change happen at the same time? Sometimes oil from the K&N can contaminate the sensors and give you bad economy.
    How badly was the muffler damaged? It could have broken a pipe internally and now is more restrictive.
    Visit my Facebook page
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    Quote Originally Posted by Not_An_Abba_Fan View Post
    ^ Very plausible, good point ^
    All it would take is an internal baffle to be out of place a little bit by the impact, and that could definitely cause more restrictive air flow. The damage wouldnt be visible from the outside.
    The fact that you've noticed less fuel economy straight away can easily be confirmed by putting the other ones back on. 1L difference is substantial in the long run.
    Got a mate you can borrow mufflers from to test different stock ones?
    Otherwise try and pick up a stock set via ebay, there would be plenty of people getting rid of stock units because of aftermarket installs.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Couple questions:
    1. Did the disconnect the battery when they installed the exhaust? This could account for the sudden increase. I find that just after filling up and resetting trip comp my fuel average is high and after driving for a while it gets better. So if they disconnected the battery the trip comp would have reset?
    2. Now that your exhaust is making more noise, is it potentially your foot giving the command to make the noise more often that is affecting your average fule usage?
    Just things to consider.
    Hope it helps a bit.
    2011 SV6 Sedan
    Aug 2011
    Gold Coast
    thanks for everyone's input, Im only shy of 3/4 of this tank finishing so i will wait and see how i go next fill up. This current tank saw me replace the straight through pipes with originals so maybe it was adjusting itself early in the tank (ie first 1/4) hence the higher consumption avg now at the end of the tank. If i don't go back down to my 10ish avg since new I think the post regarding dislodged baffle maybe the culprit??? Their is no other explaination. Other than that i could get Lukeys / redbacks put in the straight through pipes between flange point and tips???? Do you think it would get rid of the drone????
    UFO's Avatar
    UFO
    Oct 2009
    Quote Originally Posted by warnzie85 View Post
    Might. Only way to get rid of cabin drone is to either muffler up or insulate. Trial and error is this instance mate, no real short cuts.
    2011 SV6 Sedan
    Aug 2011
    Gold Coast
    Is it worth taking out the "mid section" i think its call where it's 2inch and replacing with 2.25? Will this quieten it down?
  1. [NSW] Standard ve ss rear mufflers
    By SHEENY05 in forum Parts And Other Items For Sale
    Last Post: 19-08-2011, 09:46 PM
  2. [QLD] Fs qld:catback standard ve 6ltr calais exhaust with mufflers
    By warrick in forum Parts And Other Items For Sale
    Last Post: 27-06-2011, 11:27 PM
  3. red back mufflers
    By craigburto in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-01-2010, 09:47 PM
  4. increased fuel consupmtion
    By nemesis_adrasteia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2009, 05:41 PM
  5. LPG Fuel comsumption
    By electro cruiser in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-08-2008, 03:06 PM
