Results 1 to 6 of 6
Thread: Ve clutch
    VE SV6 UTE
    Feb 2011
    Penrith
    Default Ve clutch
    Hey guys my clutch in my ve sv6 has started slipping.. so if anyone has replaced them before I'd be grateful for any advice or even brand names you can point out. Also does the fly also need to be replaced? Cheers.
    TinSnips's Avatar
    TinSnips is offline Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    Exedey have a kit for the V6s. Heard nothing but good things. Comes with a solid fly wheel.
    VX acclaim S2
    Oct 2009
    Do it yourself easy job, bell housing bolts, tailshaft bolts, pull out box, take off pressure plate and clutch plate, machine flywheel if necessary, put new clutch plate and pressure plate on, roughly line up, slip her in, re attatch links and torque bolts
    VE Commodore SS Thunder Ute
    Jun 2011
    Moree
    Holden VE SS Thunder Ute
    Oct 2009
    yes, I have had mine on my old alloy VE SV6 ute replaced. Due to being a dual mass flywheel, holden advised that you couldn't machine it, and that a new clutch and flywheel would be needed. Luckily mine was replaced at 2000km from brand new due to a fault from production. One of my mates just had his clutch converted to a heavy duty solid flywheel "aftermarket" from holden for $1600 inc install.
    calais turbo, ve ssv ute
    Jun 2011
    bankstown
    i had the solid fly wheel and extra heavy duty clutch replace the dual mass flywheel clutch in my old vz best thing you will ever do for the car!!!
  1. VX Clutch - How worn is this clutch..??
    By RvtRvx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2011, 12:22 AM
  2. clutch is making a loud pop sound when i push the clutch in
    By giffo2010 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2011, 04:37 PM
  3. [WA] VT-Z LS1 clutch master+slave cyl+reservoir + VX clutch pedal **SOLD**
    By savage1987 in forum Parts And Other Items For Sale
    Last Post: 23-05-2010, 11:22 PM
  4. HSV clutch into SV6?
    By kuzman89 in forum VE Holden Commodore (2006 - ?)
    Last Post: 22-01-2010, 10:08 AM
  5. Clutch
    By coolvxss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2008, 01:46 AM
