Results 1 to 4 of 4
Thread: 08 VE SV6 Air conditioning won't turn off!
    VE SV6 Ute
    Aug 2011
    Default 08 VE SV6 Air conditioning won't turn off!
    Hi all,
    On the way home this afternoon I couldn't get my air con to turn off?? When I push the button in, the yellow light stays on. Even if I turn the fan speed control anticlockwise all the way to left it still won't turn off. Has this happened to anybody or do you know a fix?
    Cheers, Matt
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Is it on re-circ or window demist?
    I don't think you can turn the air-con off when those modes are selected.
    VE SV6
    Oct 2010
    newcastle
    if the above isnt the solution try taking off the fascia and putting it back on sometimes the pins have a spaz. To get the fascia of wrap fingers under bottom and pull like your going to snap it
    VE SV6 Ute
    Aug 2011
    Thanks guys! It was raining so I did have it on de-mist. I've only just bought the car and am unsure of the idiosyncrasies. I'll try changing the dial off de-mist in the morning. Thanks so much for your help! Much appreciated. Matt
  1. Vy Air Conditioning
    By Jono VY2 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-11-2009, 08:23 PM
  2. VR air conditioning
    By SLR in forum VR - VS
    Last Post: 17-12-2007, 07:26 PM
  3. VE Full Map/ Turn by Turn SatNav question
    By Boeing737 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2007, 10:53 AM
  4. Air Conditioning
    By kim_08 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2006, 03:29 PM
  5. Problem with amp turn on/turn off
    By don80 in forum Car Audio
    Last Post: 05-06-2005, 08:06 PM
