Results 1 to 11 of 11
Thread: Ve sv6 growler problems
    VE SV6 Ute 10
    Jul 2011
    Default Ve sv6 growler problems
    Hey. Just installed a growler kit to my ve sv6 sidi. After about 50 kms of driving my check engine light has come. Does any one have any suggestions as what could be wrong or has anybody had any similar issues. Thanks.
    2010 ve sv6 Ute
    Feb 2010
    I've had one installed on mine with no trouble. Only thing I could suggest is check the maf sensor
    VE SV6 Ute 10
    Jul 2011
    2010 ve sv6 Ute
    Feb 2010
    Dunno what to check for really. Maybe that it's all plugged
    In and secured properly maybe. It's the cable with a stick thing that gets screwed on to the growler box. There should be a hole for it. Sorry for the crap description. Other then that really I am unsure what else could be the problem
    VE SV6 Ute 10
    Jul 2011
    ah yup i know what your talking about . Just checked it seems to be all in good order. Have contacted SS Inductions to see if they have any ideas. Might take it of and replace original for now.
    VX acclaim S2
    Oct 2009
    VE SV6 Ute 10
    Jul 2011
    haha im not giving up that quick mate. Just been playing around with it. Re adjusted the earth bolt and washer and reset my battery. Now no warning lights. Still cautious though. See how it goes tomorrow!
    f6
    Feb 2011
    I see your in Brisbane if it comes up again why dont you drop in to SS inductions at Yatala and get them to have alook , they will be able to check the kit and there is an APC and Walkinshaw right next door so they will be able to check the codes for you .
    VE Poison Ivy SII SV6
    Jun 2010
    Eastern Suburbs
    Earth bolt can be easily stuffed up. Make sure you have that washer fitted properly!
    This can cause the Check light
    VE SV6 Ute 10
    Jul 2011
    Just had a call from Shane at SS inductions. Apparently some of the sv6 sidi's have been doing the same thing. So disconnecting the battery for about ten mi utes should do the trick. If not have to get it turned of by someone who tunes.
    f6
    Feb 2011
    Quote Originally Posted by Raibo View Post
    Nah mate their prolly not gonna wanna turn that off even if did get it tuned . Its probably install related I had a 2010 Sv6 SIDI and i got them to install it no problems. Its was a friday arvo and they shouted me afew JD and cokes while they installed it for me . Let me drive the SS inductions ute down to Ormeau to get the cash outa the atm .
  1. Just got the SS CAI Growler !!!!
    By kilmo in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-11-2011, 12:55 AM
  2. growler kit for ve commodore
    By acidx1 in forum VE Holden Commodore (2006 - ?)
    Last Post: 04-06-2010, 04:20 PM
  3. Vt ls1 big mouth growler-fitting problems
    By VTLS1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2010, 09:59 PM
  4. SS Growler Kit
    By Kal123 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-09-2009, 09:50 AM
  5. ss growler kit?
    By batty_123 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2009, 11:36 PM
