Results 1 to 5 of 5
Thread: VE Commodore keeps running after ignition off!
    VE Berlina
    Apr 2008
    Default VE Commodore keeps running after ignition off!
    Hi. Hoping someone may be able to shed some light on an odd issue thats popped up today. After stopping and turning the car off, the engine keeps running and accelerating. Turning ignition on and off a couple of times eventually shut it off but it happened twice on a short trip to the shops and back.
    Aside from looking like a wanker revving the crap out of my car, i hate to think what would happen if i left it in gear.
    I found this post VZ Phantom!!! from a user with similar problem with a VZ but unresolved. Replacing ECU didnt resolve.
    Any one else seen this and had any luck resolving without Holden relieving you of a months pay?
    Cheers,
    Scott
    VE International 3.6L
    Jun 2011
    Gold Coast.
    Is it under warranty? If so you should have it flat towed at the dealers expense. Sounds nasty. I would have it looked at pronto though.
    Old cars going back to the 50s and before would do that. The trick was to open the throttle fully as you turned the key off to let a rush of cool air into the cylinders. Revving was the worst thing you could do.
    These days cars shut down because everything shuts off. Or in theory they should.
    VE Berlina
    Apr 2008
    Should have said, but it's a '06 with 130,000 on the clock so no warranty left unfortunately.
    VE Berlina
    Apr 2008
    I thought I should finish off this thread in case someone else has this issue. Basically I "found" the solution when I lost my keys. When driving the car with the spare key which we've never used before, it's fine. Go figure. Will be interesting to see if the problem returns if/when I find the other key. These are the old solid (not flip out) key with the lock/unlock and boot release buttons. I wasn't aware they had a transponder or any such thing that could cause this sort of issue so maybe just a coincidence it stopped when I started using the new key...?
    At any rate, I'm happy but hoping I don't lose the last key.
    06 vz sv6
    May 2011
    south east sydney
    Check the intake manifold for any oil because that creates a thing called run-on which has the exact symptoms you described..
  1. VS Commodore running rich!!!
    By MB85WA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2011, 10:00 PM
  2. What base ignition timing are you running?
    By Slooth in forum Tuning
    Last Post: 31-07-2009, 05:44 PM
  3. Thermo fan and air con fan running when ignition lights
    By Peter4690 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2008, 05:12 PM
  4. WTB: Any 5lt or V8 Commodore. Wrecked or Running
    By jswan in forum Swap / Wanted to Buy / Trade
    Last Post: 11-01-2007, 08:10 AM
  5. Running Jvc headunit with the ignition off
    By ad_man53 in forum Car Audio
    Last Post: 25-11-2005, 12:16 PM
