Page 1 of 3 123 LastLast
Results 1 to 25 of 63
Like Tree3Likes
Thread: Green Badges??
    VE SV6 Commodore Ute
    Aug 2009
    Default Green Badges??
    hey guys i was just wondering if anyone has sprayed their holden badges and SV6/SS badges green?
    Im waiting on the black and green numberplates from the RTA. (if you havent seen them there is an example below).
    So really i was wanting my badges to match the plates... Thoughts ?
    VH SL/E...'09 dual cab 4X4 hilux
    Mar 2011
    roxby downs
    Aug 2009
    i thought of it but if you take off the front badge youre left with the badge shape still.. and ive looked, i dont think anyone makes a plain grill yet. Apart from the VK grill that fits from HDT but its like $380.
    VE ATOMIC SV6
    May 2011
    Black and Green is a good combo, im doing it myself except opposite . Green car with black parts
    But simiilar to you a guy named BONNERS on thsi forum has done some things so you might wana check his thread. He doesnt have green holden badges but he has green stripe, green brakes and his SS badges painted green.
    Aug 2009
    Quote Originally Posted by HussySV6 View Post
    thanks mate, thats what i wanted. But does anyone know who hard it is to get theses badges off to spray and put them back on. Like in the ute are there screws behind the tailgate pannel holding them on or are they sickaflexed on??
    VE ATOMIC SV6
    May 2011
    There stuck on there by glue. Dental Floss, a hair dryer and a bit of elbow grease will get them off in minutes.
    VE ATOMIC SV6
    May 2011
    this is for a VT but same concept applys. Debadge your car in 10 minutes, WARNING dial up users
    As for painting, i wouldnt have a clue. You could do a home cheap job and just dip it into some paint :P but i do remember someone on this forum wrapping the MIDDLE section in BLACK vinyl so you could do it in green? Good Luck champ
    Aug 2009
    TinSnips's Avatar
    TinSnips is online now Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    Easy enough to paint - simple as sand, prime, paint and clear. Treat yourself to new badges though and ditch the old ones - that way you don't have to stuff around with trimming the mounting tape on your existing badges. Paint the new ones up - de-badge and re-badge in one swift, stealth manoeuvre. The car won't know what hit it.
    Aug 2009
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    If you buy new badges, they come with the tape already fixed to them - just peel the backing paper off and stick them on (wipe over the paint first with IPA: Demineralised water at 1:1 first)
    Aug 2009
    awesome... green badges, i hope they look good.
    ow and i just got a set of black Advanti Chopper 20's
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    Aug 2009
    thats what i was thinking, just painting the black parts in the SV and then the lions
  15. #15
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    green lion badges might be too much - try one and see how it goes - I'd be inclined to ditch the rear one though and make the front one black. The green on the number plate and the green on the SV should be enough to carry the them
  16. #16
    MY08.5 SV6
    Aug 2005
    Loganholme, QLD
    Just don't remove the rear holden badge(the one on the boot) unless you have a direct replacement. the earlier ones on VE's apparently have 2 holes underneath it.
    Don't quote me.
    Im a true commy boy!!!
  17. #17
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    ^^ correct - seems 06 and early 07 sedans had locating holes - not sure why.. the badges don't use them.
  18. #18
    Aug 2009
  19. #19
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    I've never come across a ute with locating holes. Should be fine. Not a massive deal if there is, you just need to stick a badge back on. 99% sure that they never put the locating holes on the VE utes or wagons though. Just the early sedans.
  20. #20
    Aug 2009
    i might give this a go this arvo. getting that stick residue off is an easy job?
    i remember with my VS getting the sticky stuff off the rubber door trim was a task and a half.
  21. #21
    bladerunner's Avatar
    bladerunner is offline AUSTRALIAN MADE AND OWNED
    VE SS UTE
    Nov 2010
    brisbane nth
    Quote Originally Posted by lclynch View Post
    mine is an 08 ute. do you think ill be right?
    you"ll be fine,I agree with tinny though, no lion badge on the tailgate and a black one on the grille looks neat. It's what I've done.now I get guys wanting me to do theirs lol. The residue is not hard. Several ways to remove it, either get some eucalyptus oil and soak the residue let sit for a minute the wipe/ or gently roll/ rub with your fingers. There is a liquid called disolve it- I think it's called which you can get from supacheap or bunnings.
    im out of my mind at the moment...please leave a message
  22. #22
    VE ATOMIC SV6
    May 2011
  23. #23
    Aug 2009
    Quote Originally Posted by bladerunner View Post
    Ok sounds easy then. did you use eucalyptus oil?... im worried of hurting the paint.
    and getting it off just use fishing line ?
  24. #24
    Aug 2009
    Paint your brakes green aswell. Would look mint.
    yeah man im going to
  25. #25
    TinSnips's Avatar
    VE SS Ute M6
    Mar 2010
    Prepsol works well - just make sure you wash it off properly and don't let it dry on the paint - or 3M adhesive remover is fantastic. Stoner's Tarminator will work well and so, most likely, will white spirits. I've seen some instances where eucalyptus oil has left the paint a little dull - no doubt extreme misuse - but I'm always hesitant in using it.
    Fishing line or dental floss will work well to cut through the adhesive. And a little heat from a hair dryer won't hurt things - steer clear of heat guns though.
  1. [VIC] WTT Chev badges for Holden badges VYSS
    By Galixia in forum Swap / Wanted to Buy / Trade
    Last Post: 09-04-2010, 07:03 PM
  2. Badges Or No Badges???
    By HyperVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2008, 11:52 PM
  3. Badges Need Help
    By Ljtorrie in forum General
    Last Post: 21-03-2006, 11:55 PM
  4. Badges from XU6
    By Tradewind in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2005, 08:51 AM
  5. badges
    By oliver in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-11-2005, 08:25 PM
