Results 1 to 8 of 8
Thread: Front Strut Issue
    2010 VE SV6 Ute and 2010 VE SSV Sedan
    Nov 2009
    Default Front Strut Issue
    So the other day while looking under the bonnet I noticed that both the front strut tops seem to be sitting away from the body, what would have caused this?
    The car is fitted with Bilstein Shocks and H&R Springs...
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    I do believe this is how they sit.. I just went out and looked at my VR and its the same...
    That rubber piece moves around as you turn the steering wheel..
    Nov 2009
    Well I just wanted to know if it was normal, or if there was something wrong.
    I lowered the back of the car today, as the Bilstein shocks are adjustable, got the back 10mm lower, love it
    But what I noticed, was the front gave different measurements.
    Ground to wheel arch,
    Drivers side: 690mm
    Passenger side: just under 700mm
    Again, this brings me back to the struts, with how the top is sitting....
    But I just took measurements off mums car, stock suspension, her car is just under 10mm higher on the passenger side, like mine...
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Hmm, I can't be certain.. so Don't take my word on it..
    Nice nice..
    What I was reading online alot of people had the passenger side lower then the drivers? Might be to even out the weight when theres a driver? might just be weight in the car on one side... (etc spare tire on the side, sub on the side) or just a flaw..
    Or even the drivers side.. Might just be weight.. :\
    Those strut tops would be raised to move freely. I had my wheels turned once and had a look under the hood and it looked like the thing was bent.. but realized it was because of the way the wheel was..
    ve sv6
    Aug 2010
    over time the bearing plate will compress, making the retainer plate raise away from the strut tower, it will compress a bit quicker when its lowered because of the higher spring and shock rate, as this is the main place for give in the front strut, the bearing plate compresses changing the height of the front of the car, some times as much as 15mm.
    and as gothickidd said the drivers side idealy should be a tad higher because there is always weight (as in driver) in that side of the car and when the drivers in it it will level out more.
    jim also better off measuring from the centre of the rim/hub because it gives you a more accurate hight reading than measureing from the ground because you might have a bit less air pressure in one tyre than the other or it might have different size tyres, the hub is always in the same spot.
    VE SV6
    Apr 2009
    Strut top mounts have collapsed. It happens and will happen quicker with firmer suspension.
    I had mine replaced not to long ago. Used Pedders heavy duty rubber ones.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    As said strut top bushes collapsed, very common on VEs and you generally replace the bearings inside the bushes at the same time.
    Silver Certified.
    Nov 2009
    glenn l,
    In regards to the measurements that I've taken, I've taken measurements from the ground and the hub, and variation from each side of the car is identical, regardless of what point I take the measurement from.
    I would understand if the drivers side was slightly higher than the passenger side, to allow for the weight of the driver etc, but this is the passenger side that's higher, the drivers side is lower.
    If the strut top bushes have collapsed, I guess I better book it in to get them replaced.
  1. VE front strut issue?
    By jonnodd in forum VE Holden Commodore (2006 - ?)
    Last Post: 28-08-2011, 09:25 PM
  2. ve front strut help
    By dave38 in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-05-2011, 09:45 PM
  3. VY Front Strut
    By 71-BEETLE-SEDAN in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-04-2011, 02:37 PM
  4. Help! vp strut tower issue
    By dallascowboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-08-2010, 08:47 PM
  5. vb front strut
    By linejockey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-10-2008, 03:48 PM
