Results 1 to 10 of 10
Thread: What oi viscosityl to use in a LS2 with 170,000Klm's on the clock?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Default What oi viscosityl to use in a LS2 with 170,000Klm's on the clock?
    What oil viscosity should I be using in a LS2 that has 170,000Klm's on the clock I do a lot of highway Klm's as you can probably tell not worried about brands as I have a certain brand that I prefer, just the viscosity?
    What oi viscosityl to use in a LS2 with 170,000Klm's on the clock?-image.jpg
    Thanks for any advise cheers Pat.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    My LS1 has done 170,000 and I use 10/30 with no issues.
    Silver Certified.
    vx custom 600RR
    Oct 2010
    the higher the K's the thicker the oil should be at operating temp
    you do the math ......
    that's all i have to add
    Evoke VE HSV GTS 6.0 auto, XR6 turbo ute.
    Aug 2011
    Mount Gambier, SA
    Probably a dumb question, but what have you been running, or have you just bought the car with those ks on it?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I've been running 5w30 since I got the car and never had any oil pressure issues but I've been thinking of putting some heavy / thicker oil in because of how many klm's it has now and and it sounds a little tappy in the mornings.
    I should add I do about 50 - 60,000Klm's a year.
    VE ATOMIC SV6
    May 2011
    Quote Originally Posted by Ian Johnston View Post
    He has had the car for a minimum of 1 year as thats when he started his thread in the SHOW OFF YOUR RIDE section.
    VE ATOMIC SV6
    May 2011
    Quote Originally Posted by pjdm1980 View Post
    I've been running 5w30 since I got the car and never had any oil pressure issues but I've been thinking of putting some heavy/thicker oil in because of how many klm's it has now and and it sounds a little tappy in the mornings.
    I think its time for an upgrade :P E3 GTS in HAZARD YELLOW.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    If we weren't planning on another addition to the family in the next year (so time for house upgrade) I probably would! Lol
    2012 S2 SV6 Sedan
    Apr 2010
    Depending on your driving style should guide you in what viscosity rating to use. I would stick to the recommended weight if there are no issue such as, oil leaks, excessive oil consumption etc. The 5w30, 10w30 and if your wanting to go a little thicker nothing over 10w40. My old VT SS S2 GEN3 always used 10w30 fully syn right up till I sold it. It has 145,000klm on it and never rattled, used oil or leaked oil.
    Phil
    If your not living life on the edge, then your taking up space!
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Well looks like 10w30 it is then, thanks for the help guys.
  1. Clock
    By NeilF in forum VE Holden Commodore (2006 - ?)
    Last Post: 13-03-2008, 08:11 PM
  2. VH ~ Clock
    By SoulGrind in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-03-2007, 06:06 PM
  3. clock for VT
    By ringfeder3 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-05-2006, 02:27 PM
  4. Clock
    By VLishes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2006, 11:35 PM
  5. VN Clock
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 09:40 PM
