Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By CapriciousWL
  • 1 Post By RiCeY
Thread: Park Assist
    2007 VE Lumina
    Apr 2011
    Default Park Assist
    Hi guys,
    I drive a 2007 VE Lumina.
    I am lead to believe it came with standard reverse sensors.
    I can see the 4 sensors on the rear bumper, yet they have never beeped when I put the car in reverse. (Let alone when I get close to objects)
    Is it possible they are turned off? Or does this seem like a malfunction?
    WL Caprice
    Mar 2011
    Have you gone into the setup on the console?
    Check the wiring in the boot - if it has been in an accident, it may be disconnected.
    Put it in reverse with objects close (50 cm) from sensors - should start beeping.
    Other possibility is that if the head unit has been replaced, the input may have been droppedvand therefore won't work.
    If you have just got the car, take it back and get it repaired under warranty.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Towbar fitted? Could be faulty cover on the trailer plug as the cover disables the park assist when its open. Should be a small maget stuck to the inside of the cover, if thats gone it will need replacing.
    Silver Certified.
    WL Caprice
    Mar 2011
    Quote Originally Posted by RiCeY View Post
    Maget, magnet or maggot?
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Was a magnet but they removed the N to save weight and improve fuel economy.
    Silver Certified.
    Nothing.. yet ;)
    Sep 2011
    Heh, I chuckled.
    OP, IIRC the family's old VE Calais had an option to do with towbars etc in the menu. The family has moved to an FG Falcon now so i could be getting these mixed up, but worth checking the menu (the VE has it built into the head unit, versus the FG which has menus in the instrument cluster). Worth checking your user guide too, under reverse sensors or towbar.
  1. Help with air springs air assist.
    By DmanVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-07-2011, 09:29 PM
  2. Roadside Assist
    By satos in forum General
    Last Post: 23-04-2009, 07:58 PM
  3. Rear Park assist
    By therobbos in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-08-2008, 02:43 PM
  4. Down hill assist
    By VZ219 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-02-2007, 03:37 PM
  5. Holden Assist
    By Darren in forum General
    Last Post: 31-03-2005, 02:56 AM
