Page 1 of 2 12 LastLast
Results 1 to 25 of 46
Like Tree26Likes
Thread: First car cheap modifications
    VE 60TH ANN OMEGA
    Jul 2010
    Outer S.E Melbourne
    Default First car cheap modifications
    OK guys I am getting my hands on a 60th Anniversary Commodore (Omega) in a few weeks, what are some cheap ways to make the car look better?
    I was considering neons, spraying the calipers & mags and getting a straight through muffler. I am thinking my cap will be about $800.
    LX 8 Adventra
    Sep 2009
    WA Perth
    No to the neons, leave that for the ricers. What colour is your car and what colour are you thinking for the mags and capliers? I would say go for the calipers and maybe get some 2nd hand springs to lower it. Also you can buy some quad tip mufflers off me : ), there off a VE HSV - bugger your in melbourne, might cost a bit for postage.
    VE ATOMIC SV6
    May 2011
    Go in SHOW OFF MY RIDES section ! There is a guy named BIGBOSS he has done small mods that are very effective. Then theres Pickle46 and ItsArthurKomar.
    Edit: Here is BigBoss's thread - My Omega Mods
    Here is Pickle46's - pickle's omega
    Here is ItsArthureKomar's Its Official I own a VE Commodore OMEGA SIDI 3lt 6spd
    Here is a guy with a 60th anneversary that looks nice with small mod - My 60th Ann
    There are plenty more - just have a look through the threads ( also try the search button )
    Here is the SHOW OFF YOUR RIDE place - http://forums.justcommodores.com.au/ve-wm/
    VE 60TH ANN OMEGA
    Jul 2010
    Outer S.E Melbourne
    @RIP O5 the car is 'karma blue' - Id says its a light cobalt colour. I was thinking yellow for the calipers (?) and white for the mags -
    Thnx Hussy - will check out those links
    2007 VE SS
    Nov 2006
    wow - neons, white mags = are you sure your buying the right car? looked into a 180sx or something?
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Neons are for brothels.
    Lower it first. It's the easiest way to make a car look better without spending a bucket load of cheese.
    Pickle''s Avatar
    Pickle' is offline Donating Member
    VE Omega
    Apr 2009
    Sydney, NSW.
    No to the neons and the white mags (i quite like white wheels, just not on the VE's) You wont be able to get an exhaust and (decent) wheels for 800. I'd be dropping it a little, forget about the neons and exhaust.
    LX 8 Adventra
    Sep 2009
    WA Perth
    go with black rims and red calipers, but i would lower it first, just my opnion
    TinSnips's Avatar
    TinSnips is online now Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    VE Omega
    Nov 2010
    Hussy is on the ball, check those links mate, everything you need will be found when you click that search button :-)
    Check out my VE Commodore My Omega Mods
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Debadge and give a real good detail and polish -Almost Free
    Set of lowered springs - Should be around 500-600 fitted??
    Dark tint - Under or around 200.
    Neons will let the gay community know you want to join them.
    Cheap exhaust will cause horny cows to mount your car and try to mate with it.
    Silver Certified.
    VE 60TH ANN OMEGA
    Jul 2010
    Outer S.E Melbourne
    Quote Originally Posted by RiCeY View Post
    HAHAHAHHAHAHAHHA - I think I'll ditch the neon idea..
    VE ATOMIC SV6
    May 2011
    Quote Originally Posted by howey View Post
    Is there somthing wrong with the gay community ? Not good enough for you ? What are you tryna say ?
    NIXONLS1 is offline Banned
    my mum
    May 2009
    Bansville
  15. #15
    VE ATOMIC SV6
    May 2011
    btw guys just before anything happenes. I was just joking with the above post lol
    I LOVE BOOBIES
  16. #16
    VE Calais V 6.0L
    Aug 2011
    I have to agree with everyone here.
    I would recommend
    1) Complete Detail, spend a day cleaning, waxing, vacuuming, and scrubbing the car so it looks brand new.
    2) I have seen cat back dual tip exhausts from V8 models on eBay going cheap every once in a while (Less than $100). You will just need to find one locally to save on postage.
    This wont give you any noticeable power improvement, but its a cheap way to make th bum of the car look nicer.
    3) Debadge the back. Makes the backend look nice and clean.
    4) Convert interior lamps to white or coloured LEDs (They consume less power, have the same brightness, and last forever, plus they make the interior look more modern at night).
    5) Convert the Cluster, Radio, and LCD LEDs to a different colour. If you are competent with a soldering iron, you can do this yourself, if not, then PM phreddy - ASR Audio on how much this costs. Trust me, if you change from the Omega green to white, the interior will look at lot classier, and will be easier to read at night time.
    6) Upgrade the cluster. (If you are willing to learn, you can program up the Cluster eeprom yourself). I have seen SV6 and SS clusters on eBay go for as little as $100.
    A triple LCD berlina cluster went for $120 not that long ago. There is info on programming VE clusters available on the internet.
    7) Have a crack at installing footwell lights. You should be able to do this yourself for less than $15.
  17. #17
    VE 60TH ANN OMEGA
    Jul 2010
    Outer S.E Melbourne
    @Zerone that's alot of stuff
    Gotta question, when you're spray painting an exhaust system, do you need to use a particular paint?
  18. #18
    VE ATOMIC SV6
    May 2011
  19. #19
    VE 60TH ANN OMEGA
    Jul 2010
    Outer S.E Melbourne
    OK well I don't alot about cars (guess street cred just went into negative!) I was looking at used exhaust system parts that have discoloured or are showing signs of rust so I was thinking you could clean it up and then spray over it with Rust Guard
  20. #20
    VE Series II SS-V Redline Sportswagon A6 Phantom
    May 2011
    Shellharbour
    Ok, I have a KPM stainless catback, but I don't think it makes the car look better, apart form the tips, I don't think any Exhaust will make your car look better......but if you happen to get a flat, and have the car up on the jack, placing some mirrors on the ground, will, make the exhaust look good to anyone that passes bye!!!!!LOL
  21. #21
    VE ATOMIC SV6
    May 2011
    Well im sure you could clean it! Sorry buddy i cant help you there, maybe tinsnips can - or someone you has painted there exhaust before?
  22. #22
    VE ATOMIC SV6
    May 2011
    Genuine VE SS Sedan Rear Mufflers | eBay bid on this buddy. If you can get it for under 150 then its worth it. It wouldnt give you power but they do look good and when you floor it, it will give you a growl. BigBoss has it on his omega and i remember him saying he was gona post a video up soon so just keep an eye out on his thread.
    And if you bug him enough, he might get that video bit quicker
  23. #23
    VE 60TH ANN OMEGA
    Jul 2010
    Outer S.E Melbourne
    VE ATOMIC SV6
    May 2011
  25. #25
    VE ATOMIC SV6
    May 2011
    Also mate - PM Greg from GSL RallySport - forum sponsorer for a good price on springs for your VE - then if you can find a cheap guy to install them then
LinkBacks (?)
  1. [Ecotec] vs,v6,manual. easy cheap engin modifications
    By popenfresh32 in forum V6 Development And Modification
    Last Post: 21-12-2010, 07:36 PM
  2. Modifications to 92 VP ute
    By Sentry459 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-08-2009, 11:07 PM
  3. Replies: 18
    Last Post: 01-04-2007, 12:35 PM
  4. Cheap Modifications..
    By tr3nt in forum General Discussion
    Last Post: 12-06-2006, 04:35 PM
Tags for this Thread
