Anyone give their VE Sv6 a quick hit and time how long it took to get from 0-100?
Anyone know about VZ Sv6's also?
Cheers.
VEs do times in the mid 7's depending on transmission, driver and conditions, apparently testing has seen some do times as low as 6.5 but i think thatd be hard to achieve.
Wheels recently did a run in an auto SV6 and acheived a 6.9.
^^thats awesome
again though you gotta look at the drivers skill, amount of runs, and it was probably done a drag strip surface
I've been playing with Dashcommand lately which is time stamping a little better than every 0.3 of a second. Data recorded a 0-100 at 6.255 seconds (was lucky as stamped right on 100km/h) the other day. Probably not spot on but pretty close. Run was done in manual mode starting in second gear. Will try a run starting in 1st when I get round to it but I think would be slower due to the change...better still should drive up to Sydney and do it responsibly at the dragway rather than a country road I guess.
