Results 1 to 9 of 9
Thread: Removal of VE Ute front Seats
    Holden VE SS Ute
    Sep 2011
    Australia / Perth
    Question Removal of VE Ute front Seats
    Hey everyone,
    I'm currently in the process of installing a sound system into my ute. I want to mount the two amplifiers (Alpine PDX) in each seat and just wondering how you go about taking them out. I have seen both sides have plugs with wires and I just want to see what you have to do to remove the seats safely without tampering with anything.
    Any help would be grateful and look forward to your replies and thank you in advance
    Cheers,
    Barnzy
    WL Caprice
    Mar 2011
    I would assume there are Allen key bolts in the floor. Should be as simple as unplugging the cabling, unbolt and remove.
    If there are airbags you may need to remove fuse, disconnect battery etc. Otherwise, there may be a trip to Holden to get the console reset.
    You can't slide the seats forward and mount the amps against the rear wall?
    Do a search within the forum on seat removal - there are posts on airbags in seats and seats in other models. Should be enough info to then make an educated decision.
    TinSnips's Avatar
    TinSnips is online now Polish all the things...
    VE SS Ute M6
    Mar 2010
    Hills District, Sydney
    I disconnected the battery first, then the wires in the seat. No airbags in mine, but disconnected the power just to be on the safe side. Then just unbolted it (passenger seat only) from the floor. Not hard so much as a pain in the arse.
    vrollin is offline Banned
    VE SSV Ute
    Sep 2007
    Just wondering what the method is for removing the plastic trim around the seat frames...?
    07 VE
    Dec 2008
    SA
    Quote Originally Posted by vrollin View Post
    Broke a few of mine so be bloody careful when ya do it.
    VE SSV Ute
    Sep 2007
    Monaro CV8z
    May 2010
    While we are on the topic of seats!
    If I unplug the wiring under my seats will it remove the annoying beeping when the seat belt isn't plugged in?
    Or will it also affect other things as well?
    Some people say less talk more action, i say more torque less traction.
    Check Out My Rig Monaro CV8z
    MY09 VE SSV Ute 6.0Lt Man
    Jan 2011
    Maccas90
    The removal of the airbag fuse also dissengages the seatbelt alert. But i wouldnt recommend this unless you are running race seats with harnesses. The fuse will make all your airbags inopertable. And no one should be driving with out a seatbelt on the road.
    Jan 2011
    Aussi
    If you havent done this yet
    The VE has two bolts at the back that you need to undo. Make sure you remove the Airbag Fuse and disconect the wiring to the seats. I have removed these seats several times to put my race seats in then back to original seats.
    Remove the trim this is tricky and if not careful can break easily. Once the Bolts have been removed tilt the Seat forward the front is on a hook system and then pull back and they will slide out of the holder.
    Be carefull it is a bit tricky to get the drivers seat out the door and you can scratch and damage paint work and trim.
    Reversal for putting them back in.
  1. Rear seats removal
    By blacknight in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2011, 08:49 PM
  2. [VIC] WTB vr-vs hsv front seats and possibly rear seats aswell
    By YILDI2 in forum Swap / Wanted to Buy / Trade
    Last Post: 21-12-2010, 09:54 PM
  3. Enamel and water based paint on seats removal
    By AnDReII in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-12-2010, 02:27 PM
  4. seats (removal)
    By DarkEnvy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-07-2010, 06:43 PM
  5. Changing VX front seats to VY / VZ seats
    By cramic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-07-2010, 01:01 PM
