Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Munz
Thread: Painted Manifold
    VE ATOMIC SV6
    May 2011
    Default Painted Manifold
    Hey guys
    I saw a VX SS on here that painted his manifold atomic green, (FORGIVEME) and i was wondering if the same could be done to a VE SV6 manifold!!!
    I have seen black painted on the alloytec VZs. So painting them Green Wouldnt be a problem? Would it have to be special Paint?
    Hussy
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Don't see why not. Just have to ensure the proper process and products are used.
    So make sure you you sand the surface so the primer has something to grab. Use a plastic primer and paint over that. several coats, followed by a few clearcoats.
    One thing you will need to check is if you will need to think about a high temp paint or if a regular paint will be find.
    Good luck and keen to see the result!
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    ls1tech.com would definatly have a write up of painting your intake - the yanks love it especially painting the f.a.s.t manifold
  1. painted dash -now what else can i do?
    By kazalex in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 09:44 PM
  2. VZ Painted Dash
    By richardpalinkas in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-06-2010, 08:50 PM
  3. Replies: 7
    Last Post: 16-11-2007, 10:17 PM
  4. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
