Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By donthree
Thread: Gps
    VE BERLINA
    Feb 2010
    Post Gps
    Hi all i have just completed a GPS install to my Ve Berlina using VE OMEGA parts and came out really good, turns on and off with the ignition, cheap way of doing it as already had GPS unit, took around 1.5 hours and not much $ all parts obtained from wreckers, have uploaded photos so hope they work out
    VE BERLINA
    Feb 2010
    Post Gps
    here are some pics of my recent GPS install i did myself, 1.5 hours to do not too bad for a beginner everything looks really good good way of doing a mod without a lot of dollars being spent easy to up load maps if have too
    UFO's Avatar
    UFO
    UFO is offline I Believe
    MY10 VE Sportwagon SIDI 3L
    Oct 2009
    good one mate, id be interesting in doing the same thing.... got any other pics, or maybe even do a write up "how to" on how you set it all up. perfect position for it.... because the current display is basically useless, all information on there can be displayed in instrument panel display.
    VE BERLINA
    Feb 2010
    hi there it will only let me down load so many photos, mine is a ve berlina all i changed was the air vents/used omega ones and back air duct as well, used omega applique parts that run across dash to instruments berlina dont have holes for vent thumb wheels, used a garmin nuvi 250 series Gps used backing plate from omega lcd screen had to dremel a little out put it altogether had to buy purpose wire harness, put all back together and it works, depending where you live i could email you all my photos of install can call me on 0417189466
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    VE SS UTE
    May 2011
    SYDNEY
    VE BERLINA
    Feb 2010
    Default Gps install my ve berlina
    see other posts re install photos lost so have put up a couple more i am unable to put any more as have used up all my upload so i dont know how to put more up if you require more please post your email and i will send them to you
    Attached Thumbnails Attached Thumbnails Gps-gps-install-021.jpg   Gps-gps-install-020.jpg
